Steeda Panhard Bar and Brace
Old May 5, 2008 | 03:55 PM
07smoke's Avatar
07smoke
Default Steeda Panhard Bar and Brace
I've already installed a Steeda LCA what is the advantage of the upgraded Steeda Panhard Bra and Brace.
Old May 7, 2008 | 11:20 PM
ybnormal's Avatar
ybnormal
Default RE: Steeda Panhard Bar and Brace
I hope the suspension guru's like mr sam jump in here. But Is your car lowered? Have you measured any shift in your axle? what are your goals for your car? dd drag or auto cross. you need to give them something to go on. you can also ask some of the suspension dealers on here.
What angle do your LCA s sit at? there is a lot of eng. that goes into making the suspension do what you want it to. Hope you find what your looking for...
Old May 8, 2008 | 01:49 AM
alloutt's Avatar
alloutt
the stock ones are crap
enough said
Old May 8, 2008 | 08:06 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
An upgraded PH baris, orrather, SHOULDbe adjustable. When the car is lowered the stock, non-adjustable one, will "push" the axle off-center as the mounting points are not at the same level, relative to the axle. The adjustable bar will allow you to re-center the axle so suspension travel is proper and looks even as well.
Jazzer
Old May 8, 2008 | 05:40 PM
F1Fan's Avatar
F1Fan
ORIGINAL: 07smoke
Hi 07smoke,
Where do you live? What are the roads like where you live?How do youuse your car? Do you want to get asporty car like look and improved handlingbut get a softer ride quality? Do you want sports carhandling and smooth stable ride or are you interested in a more serioushandling car with reflexes and firmer ride to match? Do you have any other suspension upgrades installed yet? Get back to use with your thoughts on these questions and we can help youbetter!
HTH!
flash_xx
Oct 16, 2015 07:23 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 24, 2015 09:18 PM
