Crap, installed bumpstop upside down
Old Jul 1, 2008 | 03:02 PM
Vapour Trails's Avatar
Vapour Trails
Default Crap, installed bumpstop upside down
Well I just finished my steeda sport spring/HD strut mount & d-spec install today and I realized when I did my drivers side strut last night I installed the bumpstop in the wrong orientation. I noticed when I took off the passenger side today and noted the orientation. I am so mad at myself, I had instructions in the house but I didn't get them to confirm because I was sure I had the orientation correct.
Now if I want to correct this I have to pull the strut again, but now I'll probably need new hardware because they have already been re-used once.
Is this bumpstop thing a little deal or a big deal? Do I need to bother correcting it at all?
My intial test drive was very pleasing, the d-specs rule. The springs cured a lot of body roll & dive on braking and acceleration. The car reacts to the smallest steering inputs (probably thanks to the strut mounts).
Regarding the strut mounts, which way to I move them to increase negative camber, towards the engine or towards the wheel.
Old Jul 1, 2008 | 08:19 PM
Stoenr's Avatar
Stoenr
Default RE: Crap, installed bumpstop upside down
Hmm, I cant see how you did it wrong really. Upside down? No biggie. I did not even re-install mine
Old Jul 2, 2008 | 02:41 AM
F1Fan's Avatar
F1Fan
ORIGINAL: Vapour Trails
Hi Vapour Trails,
I'm happy to hear you are happy with the suspensionstuff we've been talking about.While technically the bumpstops are designed to collapse at the pointy end first but I don't see this as a problem. To increase negative camber you move the tops inward towards the center of the car.
HTH!
Old Jul 2, 2008 | 02:50 AM
Stoenr's Avatar
Stoenr
F1. how do you move the stops towards the center of the car. My understanding is that these just slide over the strut rod assembly. Upside or down, no angle available, goes according to the strut angle.
Old Jul 2, 2008 | 02:51 AM
Stoenr's Avatar
Stoenr
I think I am to tired and may have read that wrong after re-reading.
Old Jul 2, 2008 | 05:54 AM
Sleeper_08's Avatar
Sleeper_08
I did the same thing and so far have not had any problems. This is after two track days and about 500 miles on the car
Old Jul 2, 2008 | 07:23 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
ORIGINAL: F1Fan
'.....the bumpstops are designed to collapse at the pointy end first....'
HTH!
How are we laymen supposed to understand all this tech-talk?
Jazzer [8D]
Old Jul 2, 2008 | 09:19 AM
Vapour Trails
Thanks, I really did not want to pull the strut again. I'll just take a peak at it every now and then and see how it holds up.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
