Rim help
Old Jan 3, 2009 | 08:55 PM
bjames's Avatar
bjames
Default Rim help
I want to purchase 18x8 ford aluminum rims. Any problems with 255/45/18 tires?
Old Jan 3, 2009 | 09:04 PM
Sleeper_08's Avatar
Sleeper_08
Based on a random selection of brands that seems to be the minimum recommended rim size per Tire Rack. Once you know what tires you want to buy you can double check under SPECS for your tires are tirerack.com.
Old Jan 3, 2009 | 09:25 PM
Poco's Avatar
Poco
No problems there.I've run that tire size up to an 18x9 wheels.
Old Jan 3, 2009 | 09:33 PM
bjames's Avatar
bjames
Default Rim Help
ok... i check there and it says 8-9.5 under rim width range. Im assumin gim ok then?
Old Jan 3, 2009 | 09:45 PM
Sleeper_08's Avatar
Sleeper_08
Yes you are OK. It is better to be towards the upper end of the allowable range but the bottom,i.e. 8 inch, is still OK.
Old Jan 3, 2009 | 10:48 PM
bjames's Avatar
bjames
Default Rim Help
Any risks????
Old Jan 3, 2009 | 11:43 PM
Nuke's Avatar
Nuke
Providing you're using a rim width within the tire manufacturer's recommended width, no risks.
Old Jan 4, 2009 | 11:10 AM
UrS4's Avatar
UrS4
So you are buying Ford rims that are narrower than stock which are 18 x 8.5
Old Jan 4, 2009 | 03:55 PM
bjames's Avatar
bjames
Default Rim Help
According to the Ford specs they are 18X8.. You know I may just buy the gt500 oem takeoffs that alot of people are selling with the goodyear tires on them. Seems that may be easier...
Old Jan 4, 2009 | 05:22 PM
Sleeper_08's Avatar
Sleeper_08
In case you are not aware these should be 285/40/18 on the back and 255/45/18 on the front. They should bolt right on your GT.
