racing tires
Old Jan 12, 2009 | 07:48 PM
blksunshine's Avatar
blksunshine
Default racing tires
I've been looking for some cheap used R compounds to use at the track. I found some at a decent price on some Hoosier R6's, but they're 275/35/18. I do have the GT500 wheels, 18x9.5" but am concerned about that wide of tire up front. Also, my suspension is still stock. So, any thoughts on rubbing at the track?
Old Jan 12, 2009 | 08:40 PM
RodeoFlyer's Avatar
RodeoFlyer
they will clear with no issues.
Old Jan 12, 2009 | 09:02 PM
Sleeper_08's Avatar
Sleeper_08
I'm running 285/40/18 front and rear on 18 x 9.5 rims on a car lowered about 1 inch and there is only very slight rubbing at full lock.
The big benefit to running the same size front and rear is you can rotate them from front to back.
The tires you want to run should be fine.
Old Jan 12, 2009 | 09:52 PM
blksunshine
Thanks guys
Old Jan 13, 2009 | 01:33 AM
Texotic's Avatar
Texotic
you won't have any problems with the 275's even if you decide to lower... especially with the 275/35's since they're shorter tires than stock.
Old Jan 13, 2009 | 12:59 PM
Sam Strano's Avatar
Sam Strano
Former Sponsor
I and other customers of mine run 295/30-18 Hoosier's all around... and while I am stuck on 8.5's as long as I run the car in F-stock, one customer is running them on 10's.
You have *zero* fitment issues with a 275.
Old Jan 14, 2009 | 12:36 PM
Vapour Trails's Avatar
Vapour Trails
I have 285/30/18, they are fine.
Old Jan 14, 2009 | 06:03 PM
Sleeper_08's Avatar
Sleeper_08
Wow - at about 24.8/24.9 those are a lot smaller than the stock 27 inch! How is ground clearance with them?
mungodrums
Suspension
May 16, 2019 09:36 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 8, 2015 11:50 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
