(yet another) lowering/handling question
Old Feb 26, 2009 | 10:29 AM
Norm Peterson's Avatar
Norm Peterson
Here.
I have absolutely no idea what sort of use/abuse they were subjected to, but they don't look like they'd cope with wheel hop very well assuming that they did not eliminate it entirely.
Norm
Old Feb 26, 2009 | 10:47 AM
dark-army's Avatar
dark-army
hmmm.... interesting. Kinda concerned now! I'll have to look into this more. Thanks for the heads up norm!
And I think this is finally post #50 for me
Old Feb 26, 2009 | 12:52 PM
Norm Peterson
If you got the CHE 05-09 LCAs you should be OK. The connection between the LCA tube and the bushing shell looks much more substantial. Other CHE products seem to get generally good reviews.
This them? http://www.lethalperformance.com/sus...l-arms-p-17013
And just because you made me conscious of it - today is my 2nd anniversary as a member here and this is post #2500
Norm
Old Feb 26, 2009 | 05:11 PM
Sam Strano's Avatar
Sam Strano
Former Sponsor
Originally Posted by dark-army
Before everyone starts referring me to the stickies and flaming me, I read the entire sticky on lowering. It looked like people got the most help if they gave a brief idea of what they wanted to do with their cars and a budget. So from my (limited) knowledge and research, I came up with this: I want a moderate drop for appearance purposes, but my main goal is increased performance and handling. I'd like to take it to a track, but it would be primarily for street use for now. I don’t care about ride quality as much as I do performance. So I want a good base to work up from and the most initial bang for my buck. My main concern is adverse effects from simply dropping in springs. I don’t want to alter anything that would needlessly wear on the life of the car. I don’t want stress or damage or to leave out anything critical. That being said I came up with this parts list:
- Tokico adj. shocks/struts
- Steeda Sport Springs (small, 1’’ drop)
- Adj. Panhard bar, most likely BMR
- Panhard bar brace, likely steeda
- Camber bolts
~Total Cost of Parts, $960 shipped.
Now my questions are mainly about the last two items. How needed is the panhard bar brace; at only $90 it doesn’t seem like much. But will it really make or break the set-up? Can that part be swapped in later without much harm in the mean time? Also, the use of camber bolts versus the use of CC plates. They are much more expensive (+$200) and don’t seem to really deliver larger advantages over the bolts. What are your thoughts and recommendations?
I'd forgo the PHB brace and put that money to Koni's over D-specs (well documented reasons why). I think the springs are fine. I think you should have an adjustable PHB. I don't think you need camber bolts necessarily. In fact for handling and the best grip you don't want to take camber away, you want more.
Now, the cost for the above would be very much in the same total range, maybe a few bucks more because Koni's even while they are on sale, still cost more (for a damned good reason, they work better are are more durable). And yes, I've run (and sell) both. I also carry Steeda parts including their springs. And all kinds of various PHB's.
Old Feb 26, 2009 | 06:27 PM
RodeoFlyer's Avatar
RodeoFlyer
At only 1" of drop you can go without a new phb for a while if you want to. Norm's the engineer - he can give you the math. I'll just tell you the rear wont shift that much. Sam has won himself a couple autox championships with the factory bar and FRPP/Eibach springs. The FR500S cars all have stock GT phb/brace as well.
Don't worry about pinion angle, relocation brackets, etc, for what you are doing. Too many people will tell you everything you should buy. I'll tell you everything you don't.
As far as dampers - Koni if you want adjustability and Bilstein if you don't. The Tokico D-specs are only slightly better crap than the old Ilumina's. They're cheap for a reason. KW are great if you want to be cool like me ; )
....or Penske, as on my new SLA being installed next week ; )
I wouldn't bother with camber bolts. They never seem to stay put. Buy the GT500 heavy duty strut mounts. People would be surprised how much negative static camber you can run on these cars without adverse tire wear - not that you will see any. You will end up with somewhere between -.75 and -1.00, which is just fine. The far end of the factory allowance is -1.5 or -1.7, can't remember which. Camber plates would be real nice if you could afford them, but you don't NEED them.
Get some adjustable swaybar links from Sam - they're nice. The stock ones suck and you want to get the preload out of the bar.
HTH
Old Feb 26, 2009 | 07:11 PM
dark-army's Avatar
dark-army
Hey sam and rodeo, thanks for the input. I did a lot of reading on what F1fan was saying from the stickies, but hearing and reading your stuff has given me pause to consider. Just a couple more questions and I think I'll be all set to make a move. From what you guys are saying is I could get away buying just konis and steeda sport springs and be alright? Any negative camber would be slight and possibly improve handling. and if possible an adj. panhard bar. (im running 295s in the rear, so im worried even a small offset will be visible)
Sam, that price on konis is really good. Do you guys offer a military discount?
Old Feb 27, 2009 | 01:44 PM
Sam Strano's Avatar
Sam Strano
Former Sponsor
Input is always good. F1Fan hasn't been around in a while, and no all of us always agreed (which is fine). He was in love with D-specs, but was touting them long before the Koni's were around (and after having not run the Koni's from what I could tell). I sell and have personally used both, and Koni's are what I stuck with.
No matter what you need on the 'net, you need to weight it carefully (even if I'm saying it!) and read between the lines. What are you being told? What is the basis for the comment? Ask 10 different folks and you'll get maybe 15 different answers.
With about a 1" drop you're camber would still be in spec, more negative, but nothing that would absolutely require bolts/plates, etc. Because of your big rear tires I'd recommend an adjustable PHB (or a Watts link if you are more serious). Between the fact the body will shift and you have less wiggle room because of the tire (and presumably wheel) size, and the fact that the more flush the tires are with the quarter panels the more obvious it is the body is shifted, I think it's a wise idea. And adjustable PHB's start @$109.
Discounts: The Koni's are already on a big sale (some $81.20 off normal price). And to be very honest with you I'm small and do my best to sell for the best price I can all the time. As much as you deserve a discount because of your service, I'm not comfortable with charging someone else more because they aren't in the military.... So I just do what I can do....
Old Feb 27, 2009 | 02:13 PM
dark-army's Avatar
dark-army
Originally Posted by Sam Strano
No matter what you need on the 'net, you need to weight it carefully (even if I'm saying it!) and read between the lines. What are you being told? What is the basis for the comment? Ask 10 different folks and you'll get maybe 15 different answers. ....
Yeah, I'm still running some options around. Tough decisions, esp. with all the $$ involved. I want the best, but the D-specs offer the adjustability for cheaper, and they seem to be a well respected, good product. I'll think about it.
And I completely understand. Never hurts to ask though.
Old Feb 28, 2009 | 04:26 PM
BleedinBlue's Avatar
BleedinBlue
Originally Posted by Argonaut
Regards bolts vs plates - I have plates. I got them for 3 reasons: 1) replace the crappy stock upper strut mounts before they start thunking; 2) I've read again and again how bolts can slip in extreme conditions (don't want that); 3) lots of adjustment and its easy to do. You can do it in the paddock at the track.
I hate to *****, but what does this sound/act like? Since I got my car I've heard a noise from the front passenger side, it's light and I can only hear it at low speeds, windows down and while shifting weight (Accelerating/Decelerating). Suspension is 100% stock, unfortunately. I made a thread asking about this months ago but didn't get any help.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
