Another Wheel Hop thread...
Old May 14, 2009 | 07:51 AM
TonyGT's Avatar
TonyGT
Default Another Wheel Hop thread...
Did some searching about the wheel hop issues. I have a 08 GT 5 speed and get BAD wheel hop while doing burnouts. Reading through the posts on here about it were somewhat confusing. Some say to get relocation brackets, some say UCA, some LCA... so what is the REAL DEAL. I plan on lowering the GT, never really race. Just want to be able to do burnouts and not shake the car to bits. don't want to drop a ton of $$ either. What do i really need???
Old May 14, 2009 | 08:39 AM
war machine 115's Avatar
war machine 115
BMR sells an anti-wheel hop package...
http://www.lethalperformance.com/05-...ackage-p-22689
Old May 14, 2009 | 08:53 AM
TonyGT's Avatar
TonyGT
but do i need all these parts to solve the issue?
Old May 14, 2009 | 09:26 AM
08GT4U's Avatar
08GT4U
lca,uca and relocating brakets should take the problem away.
Old May 14, 2009 | 10:32 AM
Riptide's Avatar
Riptide
Just start with the LCA by themselves and see what happens.
Strano has some UMI poly bushing arms that are pretty cheap and should do just fine. If I had things to do over again I probably would've bought those over my Steeda and saved myself $45.
Old May 14, 2009 | 10:40 AM
TonyGT's Avatar
TonyGT
they are about $180. not bad... will these alone stop the hop? lol
Old May 14, 2009 | 12:17 PM
08GT4U's Avatar
08GT4U
it might not completely get rid of it but it will help for sure.
Old May 14, 2009 | 12:29 PM
Riptide's Avatar
Riptide
http://www.stranoparts.com/partdetai...D=99&ModelID=5
$114
Old May 14, 2009 | 01:18 PM
jerjan's Avatar
jerjan
The lower arms should fix it. you should not need the relocation brackets if you have not lowered the car. The upper mount has quite a bit of flex under high torque loads. if you still have some wheel hop after the lowers are replaced then you might try the upper also.
Old May 14, 2009 | 02:39 PM
TonyGT's Avatar
TonyGT
since i plan on lowering soon, should i get the adjustable ones??
