Steeda LCA relocation brackets
Old May 23, 2009 | 01:57 PM
sweetlou69's Avatar
sweetlou69
Default Steeda LCA relocation brackets
so im just about ready to pop in my steeda lca brackets. There are going in with steeda adj LCAS. im just not too familiar with them and not sure the correct setting on both as they are adjustable..i do 99% street driving, with a couple trips to the 1/4 during the summer so i dont need anything too crazy. Any input on these would be great.
Old May 23, 2009 | 02:56 PM
Sleeper_08's Avatar
Sleeper_08
This thread discusses how to set them up in terms of LCA angle
http://www.cherod.com/mustang/HowTo/LCA%20_adj.htm
Not sure what facilities you have to do the job but per the Steeda instructions "It is REQUIRED that the installation is done at a facility that is capable of welding
on the brackets with the vehicle on an alignment rack. This cannot be stressed
enough. You need to make sure your rear axle is square in the car before the
brackets are completely welded. It is also recommended that you take
measurements on the length of your wheelbase before you start this. You don’t
want it to change after the install of the brackets."
http://www.steeda.com/directions/555...racket_kit.pdf
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
UrS4
Sep 30, 2015 10:13 AM
Sep 24, 2015 09:18 PM
