Shifted rear
Hey guys, I just installed my roush rear springs, and everything went smoothly with one exception. The drivers side back wheel gap is about 1/4 -1/2 inch smaller then the drivers side front wheel gap. This situation is only the case on the drivers side, and I also notice that the rear end of the car is shifted out TOWARDS the drivers side a slight ammount. If I get a adjustable panhard bar, and torque it back to a center position, do you think this wheel gap conflict will be resolved? Im wondering if the fact that the car is swayed out towards one side is making it weigh down on that side more. Any help or advice would be greatly appreciated. Thanks, Kevin
Awesome, I will have to try that, did your passenger side sit a little higher then the drivers side??
Let the springs settle for a while and readjust the pan hard again.
Hey guys, sorry to be a pain in the *** with this, but I have one more quick question:
I installed the rear roush springs, and got a pretty big drop outta them, passenger side is identical front and back in terms of wheel gap, drivers side is still about 1/4 inch lower in back then front. My question is if I can make/buy some sort of shimmy to place UNDER the spring, on the axle below the rubber disk that the spring sits on. Im hoping this would level out the drivers side from back to front, cuz now the drivers back is lower then the front and it looks weird. Any suggestions on how to do this/where to find such a shimmy?
