question about lowering
Old Aug 18, 2009 | 11:30 PM
defiance's Avatar
defiance
Default question about lowering
so i have finally decided to lower my 06 v6, im thinking about going with H&R SS, but worried about the drop amount. Will these springs put the car's camber angle way off and could it be adjusted with one pair of camber bolts?
Any suggestions on which camber bolts i should go with?
Also when i get alignment at the shop do they adjust the bolts for you or is that your own responsibility?
Old Aug 19, 2009 | 12:24 AM
tx_zstang's Avatar
tx_zstang
do a search; there's lots of posts on those same questions.
You'd want to get a front alignment to get the camber back into spec; camber bolts usually can do that ($20-25). Camber plates are needed if you're way off, and are better, but cost a lot more.
You can run w/o the alignment for awhile, but it will be a little harder on the insides of your front tires.
And if you don't have one yet, get a rear sway bar for your v6!
Old Aug 19, 2009 | 12:29 AM
defiance's Avatar
defiance
i have used the search function to read up on camber bolts and plates and i have revised my post so i have more specific questions now
Old Aug 19, 2009 | 09:50 PM
Cal26Stang's Avatar
Cal26Stang
If you put them on get it aligned
Old Aug 19, 2009 | 11:41 PM
tx_zstang's Avatar
tx_zstang
If you're able to put the camber bolts in, and have a level surface, you can do the camber adjustment/alignment yourself and be well within spec. But toe needs to be checked, too.
Old Aug 20, 2009 | 12:34 AM
zimmyzoom's Avatar
zimmyzoom
If you only go 1 inch I wouldn't worry about it but if you go more maybe an alignment done. Go with FRPP or Eibach!!
Old Aug 20, 2009 | 05:32 AM
DarkJFMan's Avatar
DarkJFMan
Try to the bolts first and if you didn't lower it too much you should be good, CC plates are so expensive.
Old Aug 20, 2009 | 08:48 AM
degeze's Avatar
degeze
Come on in to the H&R SS family.
I have the SS's and love them, my camber was adjusted to within factory specs with one set of camber bolts. The bolts I ordered were from BMR and I believe the degree range was 2. I suggest you leave the stock bolts in and after driving you car to the alignment shop, give them the camber bolts to install and adjust.
Here is a pic of the drop...
Old Aug 20, 2009 | 11:48 AM
DLZ314's Avatar
DLZ314
As long as you don't drop more than 2" camber bolts should be just fine.
You might also want to take a look at a panhard bar to align your rear end after the drop, just saying....
Old Aug 20, 2009 | 11:56 AM
alloutt's Avatar
alloutt
shocks and struts at the same time as springs would make a nice ride
