Help! Do I need adjustable LCA's?
Here is a thread that discusses LCAs and the UCA and pinion angle
http://www.cherod.com/mustang/HowTo/LCA%20_adj.htm
damn, you're really, really low. forget the adjustable lower ca's and get an adjustable upper ca. you say it's only a vibration at wot and not at certain speeds? that tells me it's something other than pinion angle/driveline. maybe something contacting at wot.
heres a nice vid how to check your pinion angle with the 2-piece ds. didn't help me a bit with the one-piece but you can rule that out.
http://www.stangtv.com/forum/how-cha...s197-2192.html
Thanks man, I will look into the LCA relocation brackets and the adjustable LCAs. I actually so far have not had any problems with wheel hop, if I burn the back tires a bit everything seems really smooth so I don't think I have any wheel hop
