installing g trac brace
Old Dec 13, 2009 | 02:22 AM
mykim72's Avatar
mykim72
Default installing g trac brace
can you do it with ramps or does it have to be lifted? im thinking its got to be lifted but all i have are ramps...
Old Dec 13, 2009 | 02:33 PM
Red06's Avatar
Red06
I installed mine on ramps. No problem.
Old Dec 14, 2009 | 06:34 PM
Rubrignitz's Avatar
Rubrignitz
Depends on how large a guy you are :>, but yeah it can be done on ramps easily. The rear control arm bolts are on TIGHT so you may want to have a 12''+ breaker bar handy to get those loose. (I assume the g-trac connects the same as the CHE brace I've installed...on the rear CA mount bolts...looks like it does)
Old Dec 16, 2009 | 11:44 AM
Red06's Avatar
Red06
I'm about average size for a middle age guy (getting a little larger every year...) and have air tools.
I switched to 9/16" Grade 8 hex bolts in place of the 14mm Allen head bolts that came with the kit (going from memory on the sizes). I'm not a fan of Allen or Torx head bolts unless they are absolutely necessary.
Yep, installs in the same location.
Old Dec 16, 2009 | 12:54 PM
Rubrignitz's Avatar
Rubrignitz
Swapping those bolts is very smart. Wouldn't want a CA bolt breaking/loosening...that would be very bad. Sounds like you know what you're doing. It should be a piece of cake. Good luck.
mtgldr
Feb 3, 2024 09:00 PM
fastbackford351
Sep 12, 2015 09:42 AM
GentleBen
Sep 11, 2015 05:34 AM
