unusual problem?
Old Jan 15, 2010 | 10:49 PM
tlpvt's Avatar
tlpvt
Default unusual problem?
Hi all,
I hit a curb recently - the car slid on ice @~20mph or so in a parking lot; the f&%$ng curb broke off a chunk of the front right wheel lip but the tire held on and I drove home ok without any noticeable alignment issues.
next day took the car to a dealer - they replaced oem 18" wheel, checked alignment (it was not significantly out of specs), did not find any bent parts in the suspension, checked the hub/bearing, the tire did not have any noticeable uneven wear so they tell me everything is good.
then in a couple days I start noticing a weird recurring/periodic humming noise (~1sec intervals), like someting is grinding ...on/off...on/off... the noise is coming from the front ONLY between 40-45mph; if the speed is lower or higher than that - can't hear any noise. it is as if something is resonating only at certain speed.
the car drives ok oterwise, no pulling to the side, but the noise continues, again ONLY at 40-45mph.
Went back to the dealer but they coudn't find anything whong. they switched front and back wheels to rule out any wheel/tire defects but to no avail.
any suggestions/ideas?
this humming is driving me nuts :-(
Old Jan 15, 2010 | 11:02 PM
danbevsv6rumbler's Avatar
danbevsv6rumbler
bad hub bearing?
Old Jan 15, 2010 | 11:44 PM
tlpvt's Avatar
tlpvt
Originally Posted by danbevsv6rumbler
bad hub bearing?
shouldn't that be a constant, not an intermittent noise with the hub (and at all speeds?)
Old Jan 16, 2010 | 08:11 AM
07 naja's Avatar
07 naja
Check the rotor. It could be bent or cracked
Old Jan 16, 2010 | 04:27 PM
charliebrown266's Avatar
charliebrown266
I would say bad bearing! If you move the steering when at that speed does the noise come and go?
Old Jan 16, 2010 | 07:35 PM
tlpvt's Avatar
tlpvt
steering has ho effect on the noise
Old Jan 16, 2010 | 08:07 PM
jwog666's Avatar
jwog666
duplicate posts much? this is the 3rd identical thread ive seen.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
