Spring Question
Old Jan 24, 2010 | 04:34 PM
Lv XLR8N's Avatar
Lv XLR8N
Default Spring Question
If I buy new springs, do I reuse the rubber sleeve thats on the bottom of the old spring?
I actually want to keep my stock struts/springs in 1 piece. I want to buy New struts, springs, HD steeda mounts. I know I need to find a replacement boot, jouncer, and top nut. Any idea where I can get those seperately?
Old Jan 24, 2010 | 07:16 PM
Sleeper_08's Avatar
Sleeper_08
It was suggested that I reuse the vinyl sleeve at the bottom of the spring.
Old Jan 24, 2010 | 10:31 PM
Sam Strano's Avatar
Sam Strano
Former Sponsor
There is also an indexing ring you need to put on the HD mounts that you just pop off the stock Ford upper mount as well. Have no idea if that is available separately, kind of doubt it....
Old Jan 24, 2010 | 11:55 PM
6-Speed's Avatar
6-Speed
The rubber sleeve for the lower pigtail is not available separately for the 05+ springs; I have checked with my Ford dealer and they claim nothing is listed. I suspect the sleeve comes attached to the OEM springs. I have seen polyurethane sleeves for the 04 from Prothane and Energy Suspensions, but not for the 05+ models. The sleeves are attached to the OEM springs with adhesive, but you can just peel them off and re-use on your new springs.
Old Jan 25, 2010 | 12:00 AM
6-Speed's Avatar
6-Speed
I don't think those are available separately, but you can purchase the entire upper strut mount from Ford. This is the part that Sam is referring to; it just prys off the OEM strut mount for use with the HD mounts.
Old Jan 25, 2010 | 08:46 AM
Lv XLR8N's Avatar
Lv XLR8N
Wow, thanks guys. The pictures help big time. Seems almost more trouble than its worth. Newtakeoff sells pair of struts and springs $150 shipped. I can rob what I need from that maybe... Not sure its worth it to me yet.
Old Jan 25, 2010 | 09:32 AM
Lv XLR8N's Avatar
Lv XLR8N
Hey 6-speed what brand spring compressor did you use? And did it work good?
Old Jan 25, 2010 | 10:16 AM
biznazion's Avatar
biznazion
The sleeve is available - part number 20F/5R3Z5L302A. They are about 14 dollars each though. The part that I was unable to get by itself is the dust cover.
Old Jan 25, 2010 | 10:42 AM
Lv XLR8N's Avatar
Lv XLR8N
What about the rubber index ring?
Old Jan 25, 2010 | 10:51 AM
biznazion's Avatar
biznazion
Not by itself - you would have to purchase a set of stock strut mounts to get them since it's part of the strut mount. Another part you can't get by itself is the bump stop, but I was able to get a suitable replacement from Ground Control for those.
