Need better handling HELP
Old Jan 27, 2010 | 08:58 PM
djmessick's Avatar
djmessick
Default Need better handling HELP
I have an 2005 mustang Gt convertible,
as of right now i have a
Procharger 1SC-1 supercharger kit
3.73 rear end
and a custom tune
last time i had it dyno i put down 478 rwhp
my problem is now it doesn't handle... and instead of doing trail and error i figured i would as the pros here... i dont want just drag strip... i love mountain driving, but right now all i do is spin and i have a good bit of wheel hop...
any advice would be amazing....
Thanks again
Old Jan 27, 2010 | 09:22 PM
peetiewonder's Avatar
peetiewonder
i would start with wheels and tires, 478hp through crappy 235s doesnt sound kosher to me.
Old Jan 27, 2010 | 09:25 PM
djmessick's Avatar
djmessick
Yea i know i need to upgrade the tires... any suggestions??? I wanted to change from the 235/55 to the 255/50 cause the are the same hight and i wouldn't have to get the computer tuned again... But the only tire i've found in that size is the BFG KDWS
Old Jan 27, 2010 | 09:41 PM
GlassVapor's Avatar
GlassVapor
Tires and lower it
Old Jan 27, 2010 | 09:44 PM
Sleeper_08's Avatar
Sleeper_08
I'm only running 445 flywheel HP and caneasily spin my 385/40/18 BFG KDW2 high performance summer tires.
With that kind of horsepower you will either need to develop a very sensitive throttle technique or get yourself somereally good tires.
Finding wide tires with a 27 inch stock diameter is sometimes hard but they are our there.
Try a search at www.tirerack.com on 285/40/18 and select only performance summer tire types to see what you get.
You will also need wider rims for the wider rubber.
Old Jan 27, 2010 | 09:47 PM
peetiewonder
i would reccomend nt555s or nt05s or falken rt615s in like a 285-295
Old Jan 27, 2010 | 09:51 PM
GlassVapor's Avatar
GlassVapor
Curious how you arrived at that flywheel hp #??
Old Jan 27, 2010 | 10:43 PM
djmessick's Avatar
djmessick
Why don't they make a 17X10 for the s197? I mean I really didn't want to go to a 18 inch just for a wider wheel... And I keep hearing to put after market upper and lower control arms... What's the advantage? Disadvantage? And won't I spin more if I lower it?
Thanks again guys I really love the advice!
Old Jan 28, 2010 | 02:20 AM
foolio2k4's Avatar
foolio2k4
LOL please tell me you mean 285. Or those are some mofukin large azz rims my friend. hahaha.
+1 on 285 width sticky tires. Looks like you need lots of grip.
Old Jan 28, 2010 | 03:50 AM
peetiewonder
you can find 17x10s, just make sure u get the correct offset ~45 offset. i know 5zigen fn01rc's come in 17x10s no problem. But on the other hand seems to me u should go 18s because with 400+ hp u probably want to stop too so big brakes should be on your agenda, in which case, 17s probably wont cut it.
