sway bar end link...
Old Apr 10, 2010 | 01:14 AM
mstngsule68's Avatar
mstngsule68
Default sway bar end link...
K so when i had the 'stang at the dealership getting the maintance done... they pointed out that one sway bar end link was installed in-properly. The pass. side i guess should be vertically, and its installed into the other hole on the strut, then go to the driverside, and its installed straight up, so next time i had it in for service, at a different dealer (one that i trust more), they said that it doesn't matter and its fine...... so is one dealer wrong and trying to steal money, or are they right and the other doesnt care???...
Old Apr 10, 2010 | 06:01 AM
nite's Avatar
nite
it shouldn't matter as far as your handling is concerned, but may have put some undue stress on the link, as it's designed to be in a vertical position.
Old Apr 10, 2010 | 03:49 PM
157dB's Avatar
157dB
Cut & Paste Expert
The two mounting points that are available for the sway bar
link make the strut so it will work on either side.
But only one hole should be used for the sway bar end link.
The rear hole on both sides. The length between the sway bar
ends is and will be different if you use the rear hole on one side
and the front holes on the other side. This will put the bar in a bind
at ride height. It will essentially be 'pre-loaded' one way and that
front corner will be the first to dive into a turn.
Its not right and they (or you) heed to fix it asap.
So if you fix it ,be awar ethat it is in a bind when you
go to remove the wrongly placed end link to move it to
the proper hole...
Old Apr 11, 2010 | 12:35 AM
mstngsule68
hm, now i question that dealership.... k so for just changing it, just back it out slowly and be aware that it might have tension.. and put it in the new hole and torque to 85lb right? anything else to be aware or tips?
Old Apr 11, 2010 | 08:08 AM
Sleeper_08's Avatar
Sleeper_08
Getting the stock links up to torque is difficult. The best approach I've seen per post #15 in this link
https://mustangforums.com/forum/s197...ml#post6897725
There are also apparently new end links from Ford that are easier to install per post #2 here
https://mustangforums.com/forum/s197...-endlinks.html
Old Apr 11, 2010 | 08:36 AM
jahudso2's Avatar
jahudso2
Yeah i would just get the new endlinks from ford so you dont have to worry about those things coming loose all the time. I blue locktited the hell out of those end links and still couldnt keep them from clunking. The new design is much better
Old Apr 11, 2010 | 05:26 PM
157dB's Avatar
157dB
Cut & Paste Expert
+1 on the new design...
Old Apr 11, 2010 | 11:58 PM
mstngsule68
k well i guess ill just try to get a torque on it, see it stays, otherwise just pick up a lock nut and some blue on it, but first i guess i should pull out the 'ol warranty papers and see what i can bi*** the dealer out for.....lol thanks guys i appreciate it alot...
Old Apr 11, 2010 | 11:59 PM
mstngsule68
hey one more thing, i just had my alignment done a couple months ago, would by changing this to the other hole change the alignment at all?
Old Apr 12, 2010 | 07:47 AM
dkegel's Avatar
dkegel
No.
Dave
