Can anyone give me some specs on the stock 18's I have on my 2010GT..looking for the offset to see what kind of wheel I can get when i am shopping for them.
I know the offset for the stock '05 thru '09 wheels were in the 45-50mm range, depending on which wheel. You can probably get the specs off the SVT or Ford parts website. I doubt the offset changed for the '10.
yea i got the same wheels as 05rag..wow I thought they were 18x8's...hmmm I can put a nicer size tire on them then these little 235's that came on it
Here is a link to a tire size calculator. Very nice to know existing size vs others to get a comparison and also find out how it will affect the speedo.
I've run across several on craigslist that were 8" wide. the easiest way to check is to look at the inside of your rim. it will have a stamped marking saying 18x8 or 18x8.5
I would do as Tylus suggests - take a wheel off and look. They also have the offset stamped into the back. At least they do in the earlier 18" bullitt wheels.
