Clunking over bumps
Old Jun 17, 2010 | 10:16 AM
  #21
Riptide's Avatar
Riptide
Originally Posted by Just1Guy
I paid $36 for everything.
Good for you. That isn't even close to what I was quoted by my dealer and they get the parts from the same place yours does.
Old Jun 17, 2010 | 10:22 AM
  #22
Just1Guy's Avatar
Just1Guy
Originally Posted by Rubrignitz
Yeah, the svtperformance link lists the strength of 9/16 as opposed to 12-14mm metric. The 9/16 @ 10.9 is more than strong enough. Those are beefy freakin' bolts.
I didn't check the link. Just wanted to get that out there for those that don't know.
And yes, those are beefy bolts!
Old Jun 19, 2010 | 03:48 AM
  #23
808muscle's Avatar
808muscle
I just installed some flowmasters axle backs and now it sounds like my exhaust is hanging and bouncing off the floor boards when I hit bumps in the road. I checked it all out and cannot find a spot that rubs or is loose. I cannot even move the pipes enough to hit anything. I even took the mufflers off and reinstalled them....noise is still there. Gonna jack it up again this weekend and keep looking. What in the rear suspension could be knocking around back there? I am at a loss.
Old Jun 19, 2010 | 07:28 AM
  #24
Norm Peterson's Avatar
Norm Peterson
Does it make the noise when you first drive it and the pipes have not had enough time to fully heat up? Or just when everything is hot? What I'm getting at is thermal expansion will close up a small clearance that you absolutely cannot force shut by hand. Maybe not even with a come-along. If this is the case, look for small clearances where an exhaust system component passes closely in front of some piece of chassis.
If you had to loosen anything at all during your install, check it for proper torque.
Norm
Old Jun 20, 2010 | 09:29 AM
  #25
Just1Guy's Avatar
Just1Guy
The stock motor mounts are so floppy that they allow the motor to twist enough to bounce the tailpipes off of the bumper cover.
Old Jun 20, 2010 | 09:31 AM
  #26
Just1Guy's Avatar
Just1Guy
Sorry, next time I won't bring up the fact that some things can be had for less money. Spend away Mr. Moneybags.
Old Jun 21, 2010 | 04:17 PM
  #27
Riptide's Avatar
Riptide
Perhaps you could maybe indicate WHERE you got all those fasteners for so much less than the Ford dealer? That would be a lot more help than simply spitting out "Well I got them for less" which is essentially all you did there. They weren't Ford parts were they?
Old Jun 22, 2010 | 06:24 AM
  #28
Norm Peterson
Tactics like overt boasting and not telling the whole story does not constitute tech, and it certainly isn't very helpful.
Where can the rest of us come by this sort of deal?
Norm
Old Jun 22, 2010 | 12:38 PM
  #29
Vapour Trails's Avatar
Vapour Trails
The stock bolts can be re-used several times. I've reused every fastener in my suspension. I check them periodically for torque and they still meet requirements years after the fact.
This is simply Ford CYA. I can't believe how many people they've hooked.
Just1Guy is that douchebag Squidd from All Ford Mustangs that is hated everywhere he goes.
Old Jun 22, 2010 | 02:52 PM
  #30
Just1Guy's Avatar
Just1Guy
Norm
THE FORD DEALER.........twice
