Squeaking noise from rear
I've had a random squeak coming from the rear of my car over the past 2 months or so. Mine was mainly on tip in/ tip out. It turned out that the rear brake pad spring moved out of place and was scraping the caliper. I ended up swapping the inside pad to the outside and outside to inside. Now I have brake squeal haha. I assume once I apply some anti-squeal to the backplates of the pads, my issue will be fixed. I also noticed the clutch pedal squeak as well when I was searching for this problem. I tend to never notice the clutch pedal squeak when the engine is running though, so I don't think that was the original source of either of my squeaks.
OP I think I'm having the exact same problem. its a squeak that seems to be coming from the driver's side of the car. sometimes I hear it and think that its coming from around the front wheels and other times from the back, mostly back. but squeaks are hard to pinpoint. I hear it when I have load on the driveline, particularly when the revs are very low and I begin to accelerate. it seems like the more load the louder it is, for example, when I'm on an incline it's more noticable. I hear it in every gear but it seems to be worst when starting from a stop and when I'm in 5th with low revs. It's been there for about 2 months and has been getting worse. I'd love to know what it is so I can fix it.
So just an update...
I had my car at the dealer yesterday, and with all the rain in the Northeast, it seemed to quiet the noise down. Anyhow, my mechanic said he noticed rub marks on the Ebrake cable where it passes through the rear LCA. He put a piece of rubber around the cable in an attempt to quiet the noise. So when it dries up around here, I'll be keeping an ear out for it. Hopefully that helps, because that squeek is just annoying
I have the exact same squeak on an 06 GT. It squeaks when shifting under moderate to heavy acceleration (as the suspension settles back to static levels). Also if I back up and brake hard, it will squeak as it settles. I found the same rub marks on the parking brake cables and coated them with white lithium grease, to no avail. I also got under the rear and sprayed silicone on every bushing (Control arms, sway bar, muffler mounts), no luck. I will be very interested to hear if the rubber solved your problem.
I have a very similar problem sounds like a squeak but i can only make it happen while driving over a bumpy road. Ive done the same type of jouncing the suspension and i cant re create is at all. My shocks def arnt oily granted i have about 65k miles. Ill have to peak around my ebrake cable see maybe if i have the same kinda rub issue cuz the ****s really annoyinging. Ive also heard it may also be a spring isolater as they dry out over time. But im guessing ur 09 dosnt have anywhere near 60k miles lol
I hope this helps you I had a squeak that drove me nuts also over the right rear tire that would come and go bumps made it worse and found that after my exhaust heated up the Bassani tips would move and rub on the bumper. when the exhaust cools down after a few minutes the tips would go back to center
My car had a difficult to diagnose squeak, which sounded like it came from the rear suspension. Heard it when going over even small bumps in the road. Dealer replaced one of the rear shocks and was about to replace the sway bar when a sharp service writer jumped in the back seat and found the source to be in the driver's side seat belt retraction mechanism. He had the interior guys make some adjustments and after that I never heard the noise again. Sometimes the source of noise heard inside the car is difficult to pin point.
Norm
