Edelbrock Panhard bar
Old Dec 22, 2010 | 08:16 PM
dixiemustang's Avatar
dixiemustang
Default Edelbrock Panhard bar
I just installed a Edelbrock adj panhard bar and I noticed that it says to torque the bolts down to 50 ft lbs. I thought the mounting bolts where supposed to be torqued to 129 ft lbs. Can some one help me clear this up. I don't want to be driving down the road and have my panhard bar fall off or do I want to ruin the new bar by over tightening it. Thanks
Old Dec 22, 2010 | 10:50 PM
chrumck's Avatar
chrumck
I'd rather lean towards 129ftlbs. Did you reuse the OEM bolts and nuts?
Old Dec 22, 2010 | 11:40 PM
dixiemustang
Yes I did. The instructions said to clean and reuse the factory hardware.
Old Dec 23, 2010 | 07:31 AM
chrumck's Avatar
chrumck
As I said, I'd lean towards factory 129 ftlbs, I see no reason why Edelbrock couldn't take the same torque as OEM.
Maybe try to call some tech at Edelbrock to have him explain in detail why they specify less than half of the Factory torque. If they give a good reason and insist on 50, put some blue threadlocker to make sure it doesn't get loose.
Old Dec 23, 2010 | 04:36 PM
Rubrignitz's Avatar
Rubrignitz
The only thing that comes to my mind is bushing compression. If the edelbrock doesn't employ a bushing sleeve you have the possibility of bushing failure if you overtorque the fasteners.
Old Dec 23, 2010 | 05:31 PM
Sam Strano's Avatar
Sam Strano
Former Sponsor
50 is not enough. Period. If they aren't putting in parts that can hold up to OEM torque specs, then frankly they shouldn't be selling it.
Old Dec 23, 2010 | 10:30 PM
dixiemustang
Thanks for all the input. I went ahead and torqued it to 129ft lbs. If it blows out the bushings then I will go with a better brand.
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
