umi subframes
Old May 28, 2011 | 07:44 PM
fullmonte60's Avatar
fullmonte60
Default umi subframes
got mine yesterday. bolt on. when i find someone who can weld them in i'll get 'em welded. has anyone done the bolt-in install? do you have to remove the LCA or can you just remove the back bolt & e-brake hardware. thanks.
Old Jun 6, 2011 | 09:50 PM
fullmonte60
did it. it's the front bolt and you can do it just removing the from LCA bolt. one item to watch for... on my 2007, the holes use for the larger aluminum block you insert into the front subframe for the umi piece to bolt into is a bit small and must be elongated by hand, dremmel, etc. they really improve handling w/o hurting the ride quality.
Old Jun 8, 2011 | 06:08 AM
2005Redfire6's Avatar
2005Redfire6
I actually have these on my build list, how do you like them?
Old Jun 8, 2011 | 06:31 AM
fullmonte60
i was surprised how solid the feel improved. the s197 is so much more rigid than the sn95 to start with and then adding these really tighten things up.
Old Jun 8, 2011 | 11:11 AM
2005Redfire6
Great to hear! Looking forward to getting some.
guitarman376
Oct 11, 2015 01:47 AM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
Sep 17, 2015 07:57 PM
Sep 16, 2015 07:53 PM
Sep 8, 2015 11:50 AM
