Upgrade Advice
Old Oct 14, 2011 | 03:24 PM
ryan1112's Avatar
ryan1112
The Pro-kit or Steeda sports will make it handle better. (I have ultralites but if I were to do it over again I might have gotten sports) When you lower the car that much it makes it so you hit max camber before hitting full load and start heading back towards positive camber. Your static camber will be higher but it will be lower when you need more camber under load. Thats why Steeda made the x5 ball joints and/or control arm relocation kit.
The 2 inch drop in the back changes the angle of the control arms more than other springs and will cause loss of traction unless you get relocation brackets.
We really do change a lot when we lower these cars. The good news is that there are fairly inexpensive parts that will correct the geometry after lowering.
PaulH2
20
Jan 31, 2016 09:48 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
UrS4
Sep 30, 2015 10:13 AM
