BMR panhard bar
Old Aug 23, 2012 | 08:12 PM
Tim Heenan's Avatar
Tim Heenan
Default BMR panhard bar
just wondering how to measure the rearend to see if it needs adj, where is the measurement taken, i have lowered the car with Eibach springs and would like to install bar, but need to know where to adj too
Old Aug 23, 2012 | 08:17 PM
GT50GO's Avatar
GT50GO
This should help
http://www.bmrsuspension.com/siteart/install/PHR006.pdf
Old Aug 23, 2012 | 08:20 PM
05 Mustang's Avatar
05 Mustang
If you look down the side of each of the rear fenders, you'll see that the wheel on 1 side (passender side) is in more than the other....probably like an 1/8"-1/4". With stock rims and tires it's very hard to see unless you get out there and truly start measuring and examing it. Once you put wide rims and tires on the rear, it's very apparent. The driver's side rim and tire may actually pultrude past the fender just a hair, while the other side sits inside the fender.
Old Aug 23, 2012 | 08:23 PM
Cobrakev's Avatar
Cobrakev
Tape a weighted string on the outside of the fenders. Find a point on the wheel, like the top of the rim. Measure from the string to the rim on both wheels. The passenger side should have the larger gap. The body usually shifts to the driver side when lowering the car. Sometimes the body dont move at all.
Old Aug 23, 2012 | 09:10 PM
bigstick's Avatar
bigstick
And for what it's worth...an installation video put out by BMR.
Old Aug 23, 2012 | 09:18 PM
xkape's Avatar
xkape
good info.. got one laying out n my garage i need to install.. now i know what to look for, how to measure it.. and how to install it.
Old Aug 23, 2012 | 09:48 PM
6-Speed's Avatar
6-Speed
Here's how I installed mine on a 2007:
http://www.svtperformance.com/forums...nhard-bar.html
Old Oct 14, 2012 | 01:59 PM
07stangED's Avatar
07stangED
subscribing since I just ordered one
Old Oct 17, 2012 | 07:45 AM
Norm Peterson's Avatar
Norm Peterson
There isn't much to it - just read the BMR link in post #2 and watch the BMR video linked in post #5. Don't worry if you have to go through an "adjust, drive, re-measure" sequence a couple of times.
I'm recommending the "drive" step before measuring so that the car gets settled to its normal ride height, else your measurements won't be accurate.
Good thought in the instruction link to use a threadlocker, but I'd avoid using the red stuff that takes heat to break loose.
Norm
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
