KW Coilovers Installed
I just put KW V3's on my car this weekend. What a difference over stock suspension or lowering springs. I'm really happy with the coilovers. I was expecting them to be much rougher then they are. The car is about the height of the eibach pro kit and is sitting at the kw factory set compression and rebound settings. It has very little roll and understeer around corners but is smooth enough to daily drive. Extremely precise even with -.5 degrees of camber.
Here is a pic:
I also want to say thanks to Sam Strano for all the help figuring out the right route to go
-Andrew
Here is a pic:
-Andrew
It handles very well. Riding around it is extremely smooth. With the current settings, you can't count the rocks or cracks in the road. The only rough part is sewer covers and bridges on the highway. Some bumps seem softer then stock. It rebounds really fast over bumps so you don't have the prolonged effect of the bump. It has a lot lest horizontal travel. You do not get that sense that car is leaning going through corners. It feels very flat and consistent. After having this for just about a week, I don't know how you could go another route. The two way adjust ability allows you to customize the ride and height exactly how you want
Looks like the perfect drop. Where in the height adjustment range do you have it set?
I am waiting on my car to show up and am trying to figure out which package to go with. Did you consider the Ford Racing adjustable damper kit or the Eibach coil overs as well?
I'm in it almost $3k flat with install tax shipping and alignment. I have the maximum motorsports caster camber plates on it
It's supposed to be 1" between the wheel and fender in the front and 1.25 in the back. It's settled some so might be a touch lower. I didn't really consider those. I had a lot of conversations with Sam figuring out my goals ad he suggested the kw v1 or v3s. I wanted the adjustability of the 3s so that's what i did. I couldn't be happier. I spent some time tonight adjusting them to my personal preference and the front drives like its on rails. Rear still needs some work. It's very easy to adjust. Can all be adjusted under load, no jack needed. Rebound is very easy. Front bounce is easy. The rear bounce is hard to reach without lifting it.
