2013 v6 Suspension
Old Feb 12, 2013 | 02:08 PM
Green Stang's Avatar
Green Stang
Default 2013 v6 Suspension
Ok, So I have been looking to lower my car since I purchased her. I am planning on doing new camber plates, shocks, springs, PHB.
Right now I don't have a whole lot of money to throw all this on at once, and wanted to buy them one by one.
So here is my question. I am looking at purchasing the "SR Performance Lowering Springs". In the description on American Muscle it says I will need to install the GT500 Camber plates before I put the springs on.
Is this true? Can I put these springs on my stock suspension, and upgrade the Shocks and Camber plates over the summer?
Thanks.
Old Feb 12, 2013 | 08:29 PM
shouldhavegottheGT's Avatar
shouldhavegottheGT
I saw in another post that it is not necessary but highly recommended. However if you are planning on upgrading the strut mounts, you want to do that at the same time as replacing your springs. You will have to take apart the entire assembly to get the mounts off. You'll already being doing this to replace the springs. No sense in doing it twice.
http://www.allfordmustangs.com/forum...-question.html
Old Feb 13, 2013 | 04:32 PM
UPRSharad's Avatar
UPRSharad
Former Sponsor
You can do just the springs for now, safely. But I'd install an adjustable panhard bar asap.
http://www.uprproducts.com/mustang-p...rd-bar-05.html
Old Feb 14, 2013 | 11:41 AM
AMWill's Avatar
AMWill
Former Sponsor
OP,
You can install the SR Performance springs without the GT500 strut mounts, we just don't recommend using the stock mounts. However, it's been done a lot and I personally wouldn't be too worried about not running the strut mounts if this is your daily and not a track car.
Of course, it's much easier to do all of these upgrades at once and will save you from a headache down the road. So, do as much as you can comfortably afford!
Also, once you lower the car, your rear axle won't be perfectly centered under the car anymore. You'll need an adj Panhard bar to center it again.
Let me know if you have any other questions!
Shane
wishinsky
Dec 19, 2014 12:38 PM
Jan 2, 2014 11:33 AM
SteedaBrandon
Nov 15, 2012 09:05 PM
Frustration
18
Aug 15, 2012 07:05 AM
Jarrod@latemodel
LatemodelRestoration.com
Mar 26, 2012 04:42 PM
