struts wearing out when lowered
So I did a search but couldn't seem to find my answer. I know that struts will wear out after a while when a car is lowered, but how long does it typically take? I'm debating between the sportlines and pro kit. And I know the lower the car is the quicker they wear out. Just curious if anybody has any more insight to this.
like said above. however, I'd just hold off until you can buy aftermarket struts. when you take apart the front struts to put the springs in, the factory upper strut mounts fall apart, plus the hardware for the spindle to strut mounts is "one time use only" so you'd have to buy new sets twice.
I am a firm believer of "do it once and do it right" which is why my K-springs have been sitting in a box for 2 months. konis are next on order then strut mounts etc...
plus, working on a car is no fun in 40 degree weather with no garage on an uneven parking area.
Depends on your definition of wearing out. They won't break or anything but they will show a severe lack of damping control (not that they are very good to start with on taller softer stock springs). You are asking a stock strut which is barely adequate to start with to control more spring rate, and do it in less shock travel. Doing those things well, generally means you need more rebound control, and that's something that stock dampers don't have an overabundance of to start with.....
Don't do that.... I sell Eibach, including the dampers. I think you have way better choices with better warranties too. This is a case where I'd say Koni STR.T, unless you really want to have the best damping and options to tweak the feel, then Koni Sport. STR.T's are more in the price range of the Eibach dampers, but with a lifetime warranty.
I reused my stock bolts, except the upper strut to spindle bolt. That one I replaced with an eccentric bolt.
I do not recommend that method. Yeah, it's easier, but it's also not as safe as as spring compressor (jacks can and do fail). And it's put a lot of side load on the upper strut mounts which are pretty weak to start with. And #2 it's very hard to get the spring properly seated in the notch when putting it back together... you can, but you have to have your hand up in there which isn't smart given any issue with the jack slipping or a seal failing.
