Help, Too much Anti-Squat?
Old 08-16-2014, 09:15 AM
Inspite
Inspite's Avatar
Default Help, Too much Anti-Squat?
I just installed Whiteline Lower control arms and relocation brackets. Now my LCA's are angled about 4 degrees of anti-squat. Is that too much?
On the test drive it felt like i was spinning the rear tires more than usual. Could I have less traction now?
Thanks for your help
Inspite is offline
Old 08-16-2014, 09:27 AM
gmoran1469
gmoran1469's Avatar
What do you mean 4 degrees of anti squat?
gmoran1469 is offline
Old 08-16-2014, 09:33 AM
Inspite
Inspite's Avatar
Anti-squat is when the rear of the lower control arms is below the front.
Inspite is offline
Old 08-16-2014, 11:24 AM
2007CalSpec
2007CalSpec's Avatar
This might help. Scroll down a bit.
http://www.cherod.com/mustang/HowTo/LCA%20_adj.htm
2007CalSpec is offline
Old 08-16-2014, 03:04 PM
Inspite
Inspite's Avatar
Thanks for that, but that is one of the many things I read before getting the relocation brackets. In theory I should have more traction. That is why I'm confused. Before I could punch it in first and it would hold traction, (just bearly).
Now the rear tires break loose. Maybe my tires are just getting old and don't have as much grip.
My car is a daily driver and weekend warrior. I'm just trying to decide if i'm better off without the relocation brackets.
Anybody else have an opinion?
Inspite is offline
Old 08-16-2014, 06:16 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Adjust the LCAs to be parallel to the ground and go from there.
UPRSharad is offline
Old 08-16-2014, 09:45 PM
2007CalSpec
Ok well FWIW, my LCA's were near parallel with the ground and I decided to move them to the lowest mounting holes so the rear of the LCA's angle downward. I didn't notice much a difference either. I can still spin the tires easily. Could be because I'm blown and my rear tires are almost due for replacement.
Old 08-17-2014, 11:18 AM
Inspite
Inspite's Avatar
Thanks for your input. Maybe for me relocation brackets just don't make that big of a difference and money would have been better spent somewhere else. Oh well, there not too expensive at least.
Anybody else have any thoughts?
Inspite is offline
Old 08-17-2014, 04:49 PM
CMcNam
CMcNam's Avatar
Get better tires.
CMcNam is offline
Old 08-17-2014, 07:38 PM
2007CalSpec
Check this out. I may go with this in the future.
http://www.americanmuscle.com/swarr-...rear-2005.html
Quick Reply: Help, Too much Anti-Squat?
