Upgrade coil pack
Specific to Independent Testing, yes of course they have been dyno'd like a billion times. I have not paid attention this year but I know for the last 5 seasons the guys winning in Coyote Stock have been running Granatelli regardless of which car.
Also we have a money back guarantee so if they don't work, just send them back for a refund. Can't get any easier than that.
The reason why torque raises like that on same applications is 2 fold. 1. stock coils heat soak and don't repeat when you beat on them & 2. the Granatelli Coils output much better under hard load so when the stock coils nose over at peak torque the Granatelli coils won't.
Have you seen the new throttle bodies we offer for the Coyote? The gains are little because the stock part moves "enough" to feed the engine - We still saw a gain.
My friends, these coils have been out by Granatelli since 1996. After 21 years and over 2,016,000 units sold (as of Jan 2017) no one here would be a test Guinea Pig for these coils - Seriously
Since 2011 we have sold roughly 144,000 Coyote coils sold. Not one negative word on the coyote coils, just records broken.
Stock Ford coils that test within spec will deliver all the horse power that your normally-aspirated engine will produce.
Properly-gapped plugs with a "fine-wire" design (such as BOSCH 9605, Double Iridium) will prevent spark "blow-out" at high rpm on the FOMOCO 4.6 & 5.4 configuration.
Dyno runs by product manufacturers don't tell you WHAT ELSE was done to the engines before the tests were taken.
Claims of more that 2-3 horsepower from "high-performance" coils are HIGHLY suspicious -- or downright bogus !!
I have the Granatelli SOLID connectors in my 2004 Mercury Marauder motor and swear by them over the "Springy Thingies" FORD uses but in the Marauder applications NOBODY has beat the OEM coils!!
Do the COPs in the Coyote Engines use the same OEM Springs?? If so SOLID CONNECTORS would be preferred my me!!
Its like saying at 4.6 or 5.4 engines are the same. So if we instrument 10 Mod Engines that all come from the same year, make and model car - they should all be the same right? - WRONG.
Our coils are built to exacting specs and the dyno does not lie. Peak numbers look good but our average HP and Torque is what makes us head and shoulder above the rest. Its human nature to believe what we want to. The numbers tell the story over 2,000,000
