Saleen, Roush and Boss Mustangs Discussions on Saleen, Roush, and late model Shinoda Boss Models within. SVT models, check the 4.6L section.
475 Upgrade Dyno Results
Old Aug 29, 2006 | 11:50 PM
2006RedGT's Avatar
2006RedGT
Default RE: 475 Upgrade Dyno Results
Do you have a boost gauge??
Old Aug 29, 2006 | 11:59 PM
S281 E's Avatar
S281 E
With the upgrade what should you be boosting at?
Old Aug 30, 2006 | 12:24 AM
Jonsey's Avatar
Jonsey
I have a boost guage, factory Saleen. It is just over 6 when I punched it. I beleive it is supposed to be about 8 with the kit. I could be wrong.
Old Aug 30, 2006 | 01:18 AM
dotbomb's Avatar
dotbomb
Hm so either slipping belt, wrong pulley, or bad dyno setup. I'm sure Saleen will be able to verify 1 and 2 with a simple inspection.
Old Aug 30, 2006 | 01:37 AM
Jonsey's Avatar
Jonsey
Pulley is labelled correctly so unless it had the wrong part number put on it, you can eliminate that one. You made a good point, don't eliminate a bad dyno set-up, number fudging etc.
Old Aug 30, 2006 | 11:16 AM
S281 E's Avatar
S281 E
What is the extreme boosting at? (Peak)
Old Aug 30, 2006 | 12:44 PM
HaneyMotorsport.Com's Avatar
HaneyMotorsport.Com
Banned
ORIGINAL: Jonsey
You are right in line with 6 psi. We have seen bewteen 6 and 6 1/2 psi, depending on what the car has....mods.
Casey
Old Aug 30, 2006 | 12:50 PM
Jonsey's Avatar
Jonsey
Is this with the 475 kit or stock?
Old Aug 30, 2006 | 01:22 PM
HaneyMotorsport.Com
Banned
The 6psi kit is the 475HP kit. The stock boost is about 4psi. Also, all of Saleen's HP ratings are at the crank. We have seen an average of 419HP at the rear wheels with the 475 kit.
Casey
Old Aug 30, 2006 | 11:15 PM
Jonsey's Avatar
Jonsey
419!!! That we would be great. I hope we can figure out why I am at 363-373.
