Saleen, Roush and Boss Mustangs Discussions on Saleen, Roush, and late model Shinoda Boss Models within. SVT models, check the 4.6L section.
rev restriction
Old Mar 15, 2007 | 04:06 PM
ninja205's Avatar
ninja205
Default rev restriction
ok was out in my Saleen last sunday,took someone for a ride but it wouldn't rev above 4.5k in 3rd or 4th! water temp was normal and the car had been left idling for 5-10mins before the drive, someone mentioned it could have a fail safe on the engine the same as Honda has to protect its engines, in such that the car will not rev above a certain point until the oil temp is correct,went back out for another drive from the pub and this time no problems at all, has anyone heard/had this or was it just a fluke or something?
Old Mar 15, 2007 | 04:10 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: rev restriction
That is not normal. The 3.5k-4k rev limiter is only if you're sitting out of gear and try to do that. It keeps you from free spinning your engine into oblivion. Haven't heard of that happening while driving in gear, especially 3rd or 4th hot or cold. Could just be a saleen thing built into their tunes. No stock mustang that I know of does that.
Old Mar 16, 2007 | 02:35 AM
mills281e's Avatar
mills281e
Ninja......how much time did you spend in the Pub and what were you drinking?
Old Mar 16, 2007 | 07:15 AM
ninja205's Avatar
ninja205
ORIGINAL: mills281e
well to start I don't drink! it was an hour drive to get to the pub cruising at 80-90mph all the way,the car was stood in the car park for about an hour before i took a friend for a ride with the car idling for approx 5-10mins before going out then a approx 2 miles driving before i tried to use WOT
Old Mar 17, 2007 | 03:08 AM
S281 E's Avatar
S281 E
That is weird. First time I have even heard of this happening with the new mustangs.
Old Mar 17, 2007 | 03:38 PM
SAR's Avatar
SAR
Actually this is quite normal on the new drive by wire cars, by chance did you happen to do a fast 1st to 2nd or 2nd 3rd shift? Or get on the car just after start up? The drive by wire has many fail safes that under certain instances think the engine is running away and not correct for the throttle pedal angle and speed, a fast shift and to quick to the clutch while still having some throttle applied is usually the biggest culprit. this will clear itself with either swithing the key off and restarting, or just with normal driving fora few minutes this is a bigger problem on the 05s then the later cars as the stratagy in the computer was changed to help this and not have as much sensitivity, however you can make any of the year cars do it if you really try.
Old Mar 17, 2007 | 04:59 PM
ninja205's Avatar
ninja205
ORIGINAL: SAR
I did indeed do a fast 2nd to 3rd shift this is when the restriction became apparent, it revved perfectly in 1st and 2nd to 5.5k then a fast change to 3rd and hit the wall at 4.5k! i had no choice but to drive 'normaly' back to the pub (approx 2 miles) I swithed off the engine lef tit for approx 4-5 mins then went back out and no problems at all
thanks for explaining SAR
Nick Oliver
Oct 17, 2018 04:22 AM
firehorse02
Nov 16, 2015 11:28 AM
wraith777
Sep 28, 2015 10:49 AM
Offendant
Sep 23, 2015 07:21 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
