Saleen, Roush and Boss Mustangs Discussions on Saleen, Roush, and late model Shinoda Boss Models within. SVT models, check the 4.6L section.
Anyon offer a heat exchanger setup for 99-04 Saleen s281sc?
Old Nov 5, 2007 | 11:53 AM
03GTVert's Avatar
03GTVert
Default Anyon offer a heat exchanger setup for 99-04 Saleen s281sc?
Does anyone know if there is an aftermarket heat exchanger setup for the 99-04 Saleen S281SC? Specifically I'm looking for one for my 01 'vert with a series II s/c.
I know I can get one from Saleen, but they want nearly $1100 just for the heat exchanger setup, not counting the intercooler itself. so I figured I'd ask around and see if there's an aftermarket one out there.
I need the entire heat exhchanger setup... everything EXCEPT the intercooler. (pump, heat exchanger, hoses brackets etc.)
Anyone?
Old Nov 5, 2007 | 12:19 PM
Hollywood03's Avatar
Hollywood03
Default RE: Anyon offer a heat exchanger setup for 99-04 Saleen s281sc?
LFP makes a H/E and tank Chicaine has a hose kit pump saleen.....only bracket you would need is for the pump easy fab job.
Old Nov 5, 2007 | 12:42 PM
eviligloo's Avatar
eviligloo
ORIGINAL: Hollywood03
Hey Hollywood.....what did that buy you when you did it? Temps were a lot lower? Did you see increased power or just a cooler intercooler/engine.
If this helped with the power output....any idea on #s?
Last question....how much did that set you back $-wise?
Old Nov 5, 2007 | 01:30 PM
Yellow Fever's Avatar
Yellow Fever
I bought the Heat Exchanger from LFP. It didn't come with any brackets,bolts,[/align]or instructions.It was $395.00. I haven't installed it yet.So nothing to report.[/align]
Old Nov 5, 2007 | 02:30 PM
03GTVert's Avatar
03GTVert
Thank you very much for the info! I do appreciate it.
Old Nov 5, 2007 | 05:22 PM
Hollywood03
Hey Yellow,
Are you sure you got the one for the Saleen it should have a bracket on top of the H/E plus AN fittings just like the Saleen H/E that's on your car if not they sent you the cobra H/E.
Old Nov 5, 2007 | 07:51 PM
saleen556's Avatar
saleen556
I have the Gords H/E and used the stock saleen fans. Very nicequality andmuch bigger than the saleen one.
Mr. D
Tuner Central
Aug 27, 2015 05:01 AM
bret1197
Aug 25, 2015 05:21 AM
bluovalguy
Aug 24, 2015 08:20 AM
unit91
Aug 21, 2015 11:44 PM
