What speedo cable do I need
Old Dec 15, 2017 | 08:10 PM
wvisker's Avatar
wvisker
Default What speedo cable do I need
I'm trying to fix the speedometer in my 68 mustang. The speedo cable in it is cooked. It was too close to the headers so I'm trying to replace it. However I'm confused because everything I see online tells me that I'll need to get a speedo cable along with the correct driven gear. When I go into the parts store they try to sell me a cable that has a different end. It looks similar to a worm gear. I guess I'm confused because the one they are selling me doesn't look like it will pair with the gear in the transmission. The transmission is a RUG-E2 toploader 4 speed and the drive gear inside of it has 6 teeth. Any help is appreciated. Thanks
-Wyatt
Old Dec 19, 2017 | 12:58 PM
bop11's Avatar
bop11
Here is a listing of the gears in the transmission. The gear on the cable is held on by a clip.
Old Dec 19, 2017 | 03:59 PM
groho's Avatar
groho
is there any reason why you can't take the gear off your existing cable and put it on the new cable?
Old Dec 30, 2017 | 08:46 PM
wvisker's Avatar
wvisker
The existing cable has no gear attached to it. It looks like the first example in bop11's post. Will a gear fit on both style of cables?
Old Dec 31, 2017 | 07:54 PM
imp's Avatar
imp
In addition to the already existing confusing facts, some transmissions had the hole in the tailhousing above the output shaft, some below it. That means the angle of the cable gear is different between the two types. Note the ones shown say "left tilt"; others were "right tilt". Use of the wrong tilt ate the cable gear, but usually not the transmission gear, which was more difficult to get at. Morever, some transmissions had the transmission gear mutput shaftachined into the shaft itself. To change number of teeth required changing the output shaft. I believe AODs were like that. imp
Old Jan 4, 2018 | 09:37 AM
bop11's Avatar
bop11
The gear is held to the cable with a clip. You can see the slot in the gear in the pictures. If your cable worked, but when you pulled it out does not have a gear, the clip must have come off and left the gear in the transmission housing. Hopefully it is still in position and you can pull it out. If not it probably fell into the case and should be removed.
If the speedometer never worked, you may have a different problem. We had a 67 that someone put a 89 302 from a bronco and used the Bronco Tail shaft housing with the original 67, 3 speed. The Bronco had a speedometer hole near the back of the tail shaft where the Mustang gear is near the front. So no speedometer. Ultimately put in an electronic sat-nav speed sensor, since we had updated the dash to electronic instrument.
carsofchaos
Apr 22, 2016 10:18 AM
4literranger485
May 24, 2011 05:23 PM
92TripleBlack5.0Vert
Mar 9, 2008 10:10 PM
89Convert
Oct 17, 2007 11:01 PM
93 LX FiveO
Jan 20, 2007 01:15 AM
