[FS] 03/04 Terminator Parts
![Arrow](https://mustangforums.com/forum/images/icons/icon2.gif)
Category: Accessories
Price: $0
Part fits: New Edge
Location (State/Prov): CA
Item Condition: Used
99/04 Cobra rear calipers red 2003 anniversary: $180 Shipped & Paypaled Total
Sure I have more that Im forgetting.
Pictures...
2003 Cobra Rear Calipers:
2001 Intake tube (goes between the TB and the MAF): SOLD
2001 Stock MAF unit (sensor included): SOLD!
2001 IAC Valve w/gasket & bolts (same as 99-04 except 03/04 cobra): SOLD!
2001 Oil Cooler: SOLD!
2001 Oil Adapter: SOLD!
2001 Cobra IRS Half Shafts (complete axles from inner cv joints to outter cv joints): SOLD!
2001 Cobra Pistons and Rods (8): SOLD!
2001 Alternator w/bracket SOLD!
2001 Coolant crossover tube SOLD!
2001 Cobra Amber tail lights (one broken mount bolt/stud (repairable): SOLD!
2001 Stock pulleys: SOLD!
2001 Accufab polished twin 60mm TB: SOLD!
2001 Exhaust manifolds (stock): SOLD!
2001 JLT RAI black: SOLD
2001 March UDPs (Alt, water pump, crank) Part #: 2270. SOLD!
2001 MGW Orange handle short shifter: SOLD!
2001 Stock Fuel Injectors 24lb (8): SOLD!
2001 T-3650 stock shifter: SOLD!
2001 Cruise Control Cable: SOLD!
2001 Throttle Cable: SOLD!
2001 Throttle Cable Bracket w/bolts: SOLD!
2001 Stock airbox/filter: SOLD!
2001 Lower and Upper intake/Lid: SOLD!
2001 EGR Valve & bolts: SOLD!
2001 Vaccuume Lines & sensors: SOLD!
2001 Fuel Rail Pressure Sensor: SOLD!
2001 Cobra hood great condition with hood blanket: SOLD!
2001 Compact spare tire/wheel w/jack, tire iron & hold down (Never used): TRADED!
2001 Timing cover w/ tensioner and pulleys (no sensors included): SOLD!
2001 Stock 11" clutch: Lost, cant find.
2001 Stock Flywheel 69K original miles, 75% freeway miles. Fits 96-04 but 8 bolt pattern cranks only: Lost, cant find
2001 Stock Fuel Injector Retainer Clips (8): SOLD!
2001 Stock Fuel Rails (same as 2003/2004, FRPS not included) w/bolts: SOLD!
2001 T-3650 transmission (69K original miles): SOLD!
2001 Power Steering Resivour Bracket: SOLD!
99/04 COP Covers (media blasted ready for powdercoating, polishing or ???): SOLD!
99/04 Coupe Triple Pillar Gauge Pod: SOLD!
99/04 "C" head valve covers: SOLD!
99/04 "C" head cop covers: SOLD!
99/04 JLT Heat Sheild NEW for RAI: SOLD!
03/04 Stock T-56 Shifter: SOLD!
03/04 Stock idler pulleys: SOLD!
2003 Cobra OEM Mach 460 Radio. Works good and in good condition: SOLD!
03/04 DSS Level 5 IRS Half Shafts w/hubs: SOLD!
03/04 3rd Brakelight (not cracked): SOLD!
03/04 Fore Billit Fuel Hat for 3 Ford GT Supercar pumps (separate Y block not for sale) w/ E85 protective coating: SOLD!
03/04 Zone 5 fuel driver module which manages multiple fuel pumps. SOLD!
03/04 Terminator trunk with harness and wing: (Trunklid SOLD!, Wing SOLD!)
03/04 Ford Supercar GT fuel pumps: (3) pumps SOLD
03/04 Lower crank pulley with cage: SOLD!
03/04 EGR valve SOLD
03/04 ERG tube (exhaust manifold metal pipe) SOLD
03/04 Vaccuum tubing harness SOLD
03/04 ERG sensor bracket (mounts on side of sc) SOLD
03/04 EGR sensors on bracket SOLD
![Cobra Drifter is offline](https://mustangforums.com/forum/images/kirsch/statusicon/user_offline.gif)
![Default](https://mustangforums.com/forum/images/icons/icon1.gif)
Im back from vacation and have lots of pm's to go through. Item(s) still available. I will try to catch up today and answer in the order received.
Thanks for the patience
