Rattle over bumps
Rattle over bumps
Hey Guys,
Sorry for the onslaught of threads.
My mustang makes a hard rattle sound when I bumps in the road. I want to see it is coming from the front. I am about to change my LCA so I thought I would see if there something else I should replace while I have it apart so I dont' have to pay for another alignment.
Any suggestions of what I could inspect or do a few home tests to figure out what it is. Tighten x bolts to make sure something isn't loose, etc. My roommate replaced his struts last year and one was not seated right in the rear. It made a similar sound to his when he hit a bump, but I have not replaced mine. And they appear to be in good condition. FWIW, my mustang has 112k miles.
Thanks again.
Thanks again.
I am chasing a similar sounding rattle in the front end on my 05 v6 have had control arms replaced A frame bushing tight shocks replaced not a brake rattle.running low on ideas, still rattles somewhere in the front end.
Check the front sway bar end inks. You'll need one wrench to hold the link the other to hold the bolt. Pretty common. Not saying for sure it's the issue but worth checking. I noticed it mostly going over speed bumps.
thats a good idea. its on the rack right now gettng the rear floor pan braces replaced. had the brackets made, dealer cost was too expensive for me. i creep over speed bumps,mine talks to me on uneven concrete slab streets
ive read hundreds of pages about the front end clunk on the 05-09 mustangs and the fix seems to point to the strut mounts. Im having mine replaced this Saturday with FORD RACING GT500 STYLE STRUT MOUNT , ill let you know if this works. Ive already replaced the front and rear sway bars, didnt help with the cluck,i hope this does it or its the LCA NEXT.
mIKE
mIKE
mIKE
mIKE
So here is the deal,, I had the GT500 Strut mounts installed this morning. It absolutely did away with front end cluck that was driving my nuts!! That being said after we got everything back together i noticed the drivers side wheel had a bit of slop to it. Turns out the LCA ball joint is on its way out. Not sure if i will order a complete set of LCA'S or just the ball joint. Its almost hibernation time for the stang.
As for the mounts, there awesome, the car feels better and much quieter up front.But dont forget the mounts fixed my issue but may not fix yours!
Mike
Mike
Mike
Mike
Thanks for the update.
