spark plugs for 2006 mustang gt
Old 04-23-2017, 06:49 PM
mdj89
mdj89's Avatar
Default spark plugs for 2006 mustang gt
Im looking for new spark plugs for my 2006 mustang gt and was trying to find out if they make 4 prong plugs for that model, thanks.
mdj89 is offline
Old 04-24-2017, 08:19 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
Just get a set of Champion 7989 one-piece plugs.
Dino Dino Bambino is offline
Old 04-24-2017, 12:01 PM
flash_xx
flash_xx's Avatar
Or get the oem ones and put the nickel anti seize on them and torque them to the correct spec.
flash_xx is offline
Old 04-24-2017, 01:11 PM
mdj89
mdj89's Avatar
Now what about the the ford performance cold spark plugs. Are those any good?
mdj89 is offline
Old 04-24-2017, 01:47 PM
Only if you are supercharged. Otherwise a colder plug will just make the carbon problem worse.
I'm on my second set of Champion 1-piece plugs. That's my recommendation for one-and-done.
I wouldn't spend money or waste your time with anything other than Champion or OEM for a stock car. Even a fully built one won't benefit much from a 'high tech' spark plug.
Old 04-24-2017, 01:51 PM
flash_xx
flash_xx's Avatar
only for nitrous or blown, otherwise they foul up
flash_xx is offline
Old 04-24-2017, 02:00 PM
flash_xx
flash_xx's Avatar
No car will benefit from a "high tech" sparkplug considering they are all scams.
flash_xx is offline
Old 04-24-2017, 02:01 PM
mdj89
mdj89's Avatar
Ok, I just stick with champion...thank you'll so much for the advice
mdj89 is offline
Old 04-24-2017, 02:08 PM
flash_xx
flash_xx's Avatar
Still, put some nickel antiseize on the threads and torque them properly. Also, put some dielectric grease on the coil boots.
flash_xx is offline
Old 04-24-2017, 04:31 PM
mdj89
mdj89's Avatar
Ok I sure will, thanks.
mdj89 is offline
Quick Reply: spark plugs for 2006 mustang gt
