Kenne Bell 2.8 lc install review
Well. Just completed my kb 2.8 lc install on my 14 GT vert. First I want to put aside any negative issues you may have heard about kb support. No issues. Mike was awesome and I was always able to get a hold of him by phone. Not always immediately, but I'd try again after 15 minutes if line was busy and always end up talking to him. Hey. They are busy! Good thing right? To the"kit". Truly a kit. Totally complete and well thought out from the instructions to the packaging. Definitely a kit for someone that has good mechanical skills and a good selection of tools. If you have a sears 36 pc tool set, you should pass and have a pro install. No "special" tools except a small sawzall is very helpful. I have a "hackzall" and that proved very helpful for the two fender mods necessary to accommodate the monstrous intake tube. It's going to challenge you but for us who typically do our own mods, this is a relatively straightforward install. I think I put in about 25 total hours spread out over about a month and a half. Wife had me redoing bathrooms at the same time so off and on. No major hiccups in the install. Minor issues replacing motor mounts in that had to cut the original mount stud to remove but got through it fine. Actually replacing stock motor mounts was the biggest pain of the entire job. 3 hour job.
To the meat. What a freakin beast this car is now! OMG!! The kit claims 725 at crank and I have no doubt it's in that general area. Not going to dyno for numbers. Don't care. It is mean ***. Highly recommend Kenne Bell and the kit. Totally a complete kit. Runs perfect, and again their support when needed has been first class.
You really should go get an actual dyno tune done. Not for more power, but because it's so much cheaper than another engine if your car decides it doesn't like something about the KB tune. Which does happen.
Hmmmm. Not seeing that. If that was the case shouldn't I have dunno tuned my stock motor in case it didn't like the ford tune that is identical across tens of thousands of 5.0 motors? I struggle to see any reason to dyno tune except to fine tune the tune. Trust me, I don't need 20 more hp.
Best of luck to ya then, but I've heard and seen enough stories over the years involving those with power adders and canned tunes resulting in melted pistons and bent rods to know that a few hundred dollars invested in dyno tuning to make sure everything is "safe" is very cheap insurance. It really isn't always about squeezing more hp out of your build (especially when you have a 700+ rwhp street car) so much is it is about ensuring that fuel and spark etc are where they need to be at all points between idle and redline. I'm sure you know what happens if it's just a tad lean and/or a little too much timing during a WOT pull. Of course you are ultimately responsible regardless, but if you nuke a piston or something I wouldn't expect KB to whip out their checkbook.
I hope your experience is different, congrats on your install and enjoy that power dude.
