1966 mustang door handle button sticking
Old 06-18-2017, 07:28 AM
tom taras
tom taras's Avatar
Default 1966 mustang door handle button sticking
drivers side door on my 1966 mustang convertible outside door handle button sticking-will not pop out completely after opening door-what is the issue and what is the quick fix or do i have to remove the door panel to correct the problem-and what is the correction-tks
tom taras is offline
Old 06-24-2017, 01:19 AM
drewsky
drewsky's Avatar
Pop off the door panel and spray all the moving door components with brake or carb cleaner. This is a quick easy solution but I've done this in like 5 classics. You can try to get it without taking the door panel off by spraying in the lock and around the button it may work depending on how badly its gunked up
drewsky is offline
Old 01-06-2018, 09:37 AM
R2TJL174FDNY
R2TJL174FDNY's Avatar
Unhappy
Any hints on getting the panel to pop off without causing any damage? Thanks!!
R2TJL174FDNY is offline
Old 01-17-2018, 01:14 PM
drewsky
drewsky's Avatar
a flat hear screw driver and go slowly. find the clips with your fingers, you can feel them through the vinyl.
drewsky is offline
