4.6 stroker kit?
4.6 stroker kit?
I want to up the power on my 07 GT, and I've looked at a coyote swap, but the cost is an issue. I'm looking at boring my cylinders to 304ci and making my 4.6 to 5.0 how effective/safe is this?
You could rehone the cylinders +0.002" and add a Kellogg 3.80" stroker crank to increase displacement from 4601cc (281ci) to 4942cc (302ci). Do you want to keep the engine N/A or add forced induction?
I believe the maximum safe overbore on a 4.6L aluminum block is 0.040". However on a FI engine, you'd want to preserve as much cylinder wall thickness as possible so going that high wouldn't be a good idea.
You could resleeve the block to allow the use of 3.70" pistons but that would be a very costly exercise.
There's simply no cheap way to make real power on these engines. Supercharging+reliability=forging, Nitrous+reliability=Forging, N/A power adders like cams, headers, etc +reliability= almost no power+lots of money down the drain.
The more I look into it, the more a 2011+ car makes more sense than building up a 3V.
If you're happy with 300-310rwhp you could just do the stage 1 bolt-ons (CAI, CMDPs, UDPs, midpipe, tune) that I've done, upgrade suspension/brakes/tires, call it a day, and have fun with it.
