Weird Engine Problem
Old 01-05-2018, 09:58 AM
khankold
khankold's Avatar
Default Weird Engine Problem
I have a weird problem on my 2002 mustang GT. I ended up blowing a spark plug out on my engine mid-race and had to replace the head on it. I did everything correctly with replacement on it but now my engine is acting weird. Weird as in now it won't cold start idle it just sits at its usual 760 rpm like when its warm and if i give it a little gas the rpms drop and come back up to its normal idle. Another thing my engine would hold its rpm just fine between shifting gears but now it just drops really quickly if im shifting from like 1st to 2nd or any gear for that matter. I have no check engine lights and can't seem to find the cause. HELP
khankold is offline
Old 01-05-2018, 10:51 PM
Z28KLR
Z28KLR's Avatar
Sounds IAC related, possibly.
Who told you you had to replace the entire cylinder head for a blown out plug?
Z28KLR is offline
Old 01-06-2018, 11:45 AM
khankold
khankold's Avatar
I looked through a boroscope and and the bottom part of the spark plug hole was blown out it was about an inch and a half chunk
khankold is offline
Old 01-12-2018, 02:44 PM
Buck Sergeant
Buck Sergeant's Avatar
khankold, just a guess, but I'm thinking vacuum leak. Start the engine and spray all over it with carb cleaner or WD-40. If the idle "RISES" you found the culprit.
Buck Sergeant is offline
Old 01-17-2018, 04:46 PM
WJL
WJL's Avatar
I'm with Buck Sargent, i would suggest having an fire extinguisher near by when you start spraying brake clean or carb cleaner around the manifold, just to be safe
WJL is offline
Old 01-18-2018, 07:38 AM
Buck Sergeant
Absolutely do NOT spray " brake cleaner" around anything that is hot. I only use "Carburetor Cleaner" or "WD-40," to check for vacuum leaks. Try not to spray either on hot headers. I have never had a issue with spray hitting the hot headers, but some common "safety" sense must prevail if you are new at this procedure. Oh yes, WJL is absolutely right about having a fire extinguisher at the ready.
Old 01-20-2018, 06:30 PM
tadpole1969
tadpole1969's Avatar
yeah not a good idea to spray that around anything on your motor , take it from me i was doing same crap on my work van and bam ! lit up like a roman candle, had to rip my shirt off to get it put out, thought i was gonna have to stand bk and watch it burn
tadpole1969 is offline
llamatymer
12-14-2007 09:35 AM
ben790450
10-06-2006 12:46 AM
Lynxman
08-26-2006 04:14 AM
RacquetballRyan
06-03-2006 12:39 AM
Stangdai
03-17-2006 11:00 AM
Quick Reply: Weird Engine Problem
