GZDL For Ford VCM OBD Interface Diagnostic Tool Auto Scanner USB Cable
Old 08-20-2018, 02:53 AM
08'MustangDude
08'MustangDude's Avatar
Default GZDL For Ford VCM OBD Interface Diagnostic Tool Auto Scanner USB Cable
Just got one of these, will let you know how it works:
https://www.wish.com/product/5a5464ceb4b8d9401ce2b153
Ford-VCM OBD is professional device for ford vehicles, Ford-VCM OBD has the most functions of ford vcm ids,
it is the mini version of ford vcm. Ford-VCM OBD works on ford car by OBD2 port directly. Ford-VCM OBD is
diagnostic software for Ford vehicles. It is designed for ford, mazda, and other few brand cars, working very
well with those cars 1996-2010, some 2011 cars. Ford-VCM OBD is diagnostic programmer for Ford vehicles
1996-2010. It can connect to various electronic control units (ECUs) and display identification, read and clear
fault code memory, display and record measured values and perform actuator tests, some key programmer,
etc.
Key features:
1. Support for wide range of ECUs and models
2. Easy connection via smart USB to OBD2 interface
3. Wide range of communication protocols and buses covered:
4.J1850 PWM, ISO, CAN
5. Automatic ECU recognition
6. Automatic vehicle scan
7. ECU Identification
8. Fault code (DTC) reading
9. Fault code clearing
10. Measured values / live data
11. Live data recording
12. Diagnostic protocol printing
13. Actuator tests
14. Control unit coding
15. PATS Immobilizer operations
16. Flash and serial memory programming.
Package Included:
1 x Ford-VCM OBD interface.
1 x CD-ROM with software and drivers
$18 bucks, can't beat it I suppose...
08'MustangDude is offline
Old 09-04-2018, 04:56 PM
08'MustangDude
Well, it came today, and the disc was broken in half. So I contacted WISH,
told them, SHOWED them the disc came broken. SO, they offered the typical
refund statement if that was acceptable. I said, yeah, or provide a link to the
software. Well, I got a full refund instead, AND, I was able to find the software
on my own.... Will try it out as soon as I can...
Old 09-21-2018, 03:51 AM
08'MustangDude
Doesn't work on Win10...
Old 10-14-2018, 01:01 AM
08'MustangDude
Forscan will work, just need to get a real ELM327 interface.
Old 10-14-2018, 04:13 PM
artsvettes73
artsvettes73's Avatar
Wish you all the luck with that thing, could never get it to work at all. The disc according to my computer was infected. Good Luck
artsvettes73 is offline
Old 10-15-2018, 04:17 PM
08'MustangDude
Where did you get Forscan? I got it from THEM, not a seller on-line, and my A.V. did not
detect any virus.
https://forscan.org/download.html
That's where I got the Windows version, it ran, detected the adapter, but said it's
not a true ELM327 adapter, so would not proceed. There are some China resllers
out there, modded the software to run with a knock-off ELM adapter, with the switch,
and some of them show positives for viruses when you go to install the software.
I have bought VCDS though China re-sellers, never had an issue.
Old 10-16-2018, 08:00 AM
artsvettes73
Got it off flea bay China seller
Old 10-16-2018, 05:59 PM
08'MustangDude
Any way you can ZIP the contents of the disc and send it to me?
I would like to see how they bypassed the ELM327 clones....
In the mean time, download it from Forscan, see if it works with the adapter
you got. If not, it just confirms what the China ones do.
Old 10-17-2018, 09:21 AM
artsvettes73
I can't download to a zip because of the virus threat. I looked at forscan I got dizzy lookin for what I need to download.
Old 10-17-2018, 12:47 PM
artsvettes73
Did it download on windows 10? it did for me. Haven't gone out to try it.
Quick Reply: GZDL For Ford VCM OBD Interface Diagnostic Tool Auto Scanner USB Cable
