New Struts for 06 GT
Old 01-16-2019, 11:32 AM
66and06stangs
66and06stangs's Avatar
Default New Struts for 06 GT
Does anyone have any suggestions on struts and rear shocks? When I bought the car the struts looked brand new but all of a sudden I have some serious clunking in my front end when going over a bump. Had another car guy confirm what I thought, he said "struts"... I've put new lower a arms on the car and did all the steering, those were the only thing I didn't replace, they looked new. However, I need to yank them off and put something good on that won't break the bank but take that clunk out of my front end. I see there are sets for sale, both front struts and rear shocks, but thought this forum would produce some good info. Apologies because my searches didn't come up with anything, maybe i'm not doing my searches correctly - please be easy.
Thanks!
66and06stangs is offline
Old 01-16-2019, 01:19 PM
08'MustangDude
08'MustangDude's Avatar
Mine have 120,000 miles on them, no clunking...
Check the sway bar bushings, or end links first...
08'MustangDude is offline
Old 01-16-2019, 01:29 PM
99GTvert
is my username.
99GTvert's Avatar
Yeah, my '12 clunked when the sway bar end links were bad. To test the shocks/struts, try pushing down on each corner of the car and see if it bounces up and stays or keeps moving. Non worn units should rebound and stay.
99GTvert is offline
Old 01-17-2019, 01:36 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
Clunking when going over a bump could be from worn strut mounts rather than the struts themselves. It's probably a good policy, when replacing front struts, to replace the mounts at the same time.
Other possible causes of clunks when going over bumps are worn tie rod ends, worn ball joints, worn front control arm bushings, and worn front sway bar end links.
Dino Dino Bambino is offline
Old 01-17-2019, 04:25 PM
danzcool
danzcool's Avatar
I'd say, based on your goals, go for Koni STR.T, they are the low cost/non adjustable version of Koni's.
and as Dino said replace the strut mounts at the same time, and possibly the endlinks (connects from front strut to front sway bar)
https://www.americanmuscle.com/koni-...-kit-0510.html
danzcool is offline
Old 01-17-2019, 05:27 PM
07MRMIKE
07MRMIKE's Avatar
after chasing the "clunk" for several months i finally installed Pedders quick struts and shocks, it did get rid of the noise but they are way to stiff a ride for the street. Im thinking about swapping them to koni's in the spring.
Mike
07MRMIKE is offline
Old 01-18-2019, 01:06 AM
Dino Dino Bambino
Those will also be on my shopping list for the future. I'd like slightly firmer damping but without degrading ride quality so those should do just fine. I'm running at stock ride height (need to clear local speed bumps without scraping the exhaust).
Old 01-18-2019, 07:00 AM
66and06stangs
I will definitely check these, good suggestion. I put it on jacks last night but it started raining so I called it. Hopefully this weekend I will be able to see what is up. I get a clunk then a rattle, like the front end is about to rattle off. All of the steering and ball joints have been replaced, but that doesn't mean they are still good. I'll post what I find after the weekend....
Old 01-18-2019, 07:04 AM
66and06stangs
I'm going to check out all of these things this weekend. I just need to get under her and check out what's going on under her skirts.... lol. Thanks for the suggestions.
Old 01-18-2019, 10:30 AM
Goldenpony
Goldenpony's Avatar
I installed Koni STR.T struts, rear shocks and GT500 strut mounts about 100K miles ago. Have been very happy with them.
Goldenpony is offline
Quick Reply: New Struts for 06 GT
