Electric Radiator Fans / Voltage Drop
Hello, I have. 93 GT. Having issues and I need help. I have had an erratic idle. I smoked the engine and found leaks which I fixed. I put in a new IAC. I can now get the car to idle properly and have done the base idle reset. The problem is when the car heats up, the dual electric fans infront of the radiator turn on and the voltage drops, the idle drops and hunts. After the fans cycle off the idle returns to normal but as soon as they turn back on the same problem persists. Battery tests fine. Is my alternator bad? NEED HELP!!!
luckythirteen13
Aug 26, 2006 10:22 PM
