Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
SD cam
Old Mar 8, 2008 | 06:17 PM
Alero99's Avatar
Alero99
Default SD cam
Im gonna ahve to hold out on the Heads right now but i def wanna slap an intake and cam in her
so whatCam would be good to run on a stock SD engine with a TF street heat intake?
when i do get to heads i want them to be GT40 heads
Old Mar 8, 2008 | 10:34 PM
dimebag's Avatar
dimebag
Default RE: SD cam
well... id just throw 1.7rr's on it if your keeping stock heads, but if u really want a cam, get the crower 15511, it seems to work well w. stock heads, i was going to get it when i was gonna stay stock heads
Old Mar 9, 2008 | 10:50 PM
Alero99's Avatar
Alero99
Default RE: SD cam
and if i upgrade later... GT-40 Irons (definate) this cam will work well with it?
Old Mar 10, 2008 | 03:51 PM
dimebag's Avatar
dimebag
Default RE: SD cam
yes sir, it was the cam i was originally going to get.
Old Mar 10, 2008 | 11:56 PM
Alero99's Avatar
Alero99
Default RE: SD cam
may i ask why you did not get it?
this will work with stock pistons right?
Old Mar 11, 2008 | 03:47 PM
dimebag's Avatar
dimebag
Default RE: SD cam
because when i was getting a cam it was because i threw 2 rods out of my oil pan, and had the cam shift back destroying it and my lifters... i was stuck and needed something... i was going to get that one, but there was a one month wait on it thru summit, so i said the hell w. that and bought a comp xe270... i wouldnt have put the comp piece in w. stock heads, but i was going to go w. stock heads w. the crower, and upgrade to the gt40s i have on it now... basically i was in a bind(it was my only car) and needed a cam, crower wasnt in stock so i bought the comp
yes it should, but ptv should ALWAYS be checked
Old Mar 11, 2008 | 03:59 PM
86GreenMachine's Avatar
86GreenMachine
Default RE: SD cam
Will the comp cam xe264... work on the stock e7 heads?
Old Mar 11, 2008 | 10:11 PM
dimebag's Avatar
dimebag
Default RE: SD cam
specs?
Old Mar 12, 2008 | 01:57 PM
86GreenMachine
Default RE: SD cam
Intake Exhaust
gross valve lift.512 .512
duration @
.006 tappet lift 264 270
valve timing openclosed
@ .006 INT22 BTDC62 ABDC
EXH 73 BBDC17ATDC
These specs are for cam installed
@ 110.0 intake center line
Intake Exhaust
Duration @ .050 212 218
lobe lift .3210 .3210
lobe seperation 114.
This is what the spec card said.
Old Mar 12, 2008 | 04:56 PM
dimebag's Avatar
dimebag
Default RE: SD cam
yes, but it is a little big for stock heads...
