Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
¿418W w/ SD?
Old Mar 10, 2008 | 11:22 AM
learning slowlzy's Avatar
learning slowlzy
Default ¿418W w/ SD?
so i'm just about done with my 418 build and about to put it into my 88'F250 which is SD....
ive got 202heads and cam is .493/.512" liftin/ex and 218/226 duration... trick flow intake and shorty headers..... im not sure of the comp. ratio yet but will SD work with this just 1988 computer or should i get MAF out of a mustang GT(HO) and wireing harness computer etc etc?
ive looked alot in the search but this Q still is unanswered... thanks in advance
Old Mar 10, 2008 | 04:00 PM
dimebag's Avatar
dimebag
Default RE: ¿418W w/ SD?
stock SD WILL NOT work... no way...
people have made 331s and 347s work(but not make the power they should)
and do you really think 19lb injectors would do the trick? because they wont at all
my advice... go carb'd, youll have alot more money in to mass air(big injectors, and a big maf) then you would if you just carbed it... and remember, carbs today arent like they were 20 years ago, milage wouldnt be terribly worse, and it'd be reliable
