Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
How much H/P
Old May 3, 2008 | 10:28 AM
aggiedog's Avatar
aggiedog
Default How much H/P
I was just wondering how much Horsepower you guys think i have after
all these Mods i did. Cobra intake, 65 MM throttle body, BBK EQ Lt headers, AFR 165 heads, Under drive pulleys, Mark VIII electric Rad
Fan, Delited smog pump, Walbaro 255 fuel pump, Mac Cold air intake,
Adjustable fuel presure reg set at 42, Timing set at 14. Still stock Cam
and injectors. Was hoping for around 300, do you think i made it. If
not what do you think i need to add. Many thanks, Aggie.
Old May 5, 2008 | 09:45 AM
stangbanger87's Avatar
stangbanger87
Default RE: How much H/P
increasethe cam to a xe270hr or a 15511 crower cam (.512 lift ) and spray it with 100 shot will get ya 300+ hp right now you are probly 270to 280 hp to the tire (best guess)
Old May 10, 2008 | 06:42 PM
aggiedog's Avatar
aggiedog
Just got my July 08 issue of 5.0 Mustang Super Fords. Theres an article
on Cam Shafts, on page 116 it talks about Speed Density Cams. Comp
Cams has a cam # 35-512-8. How much of a H/P gain do you think
there might be by adding this cam shaft. Thanks, Aggie.
Old May 12, 2008 | 05:12 PM
stangbanger87
idk what is the spec on the cam and we can go from there .
Old May 12, 2008 | 05:36 PM
aggiedog's Avatar
aggiedog
This is how the article reads. The 35-512-8 is for 86-88 speed density
mustangs. This cam with 0.480 inches of intake and exhaust lift and
206 (int)/ 212 (exh) degrees of duration at 0.050 inch, is compatible
with a stock EEC-IV engine management and adds more horsepower
and torque than the OEM camshafts for those particular years. Aggie.
rap87
Jan 11, 2008 05:11 PM
Stanpower
Mar 12, 2007 05:43 PM
nibotcire
Oct 26, 2006 08:09 PM
x3gop1yr
Aug 4, 2006 03:05 AM
