carb/intake question
I just bought a motor and I need to pick a intake and carb for it and was wondering if someone would recomend a setup for me? Its a 347, Eagle forged 10.5:1, AFR185 heads, and a trickflow stage II cam.
Thanks
Thanks
RPM Air Gap with a 650cfm-750cfm carb, depending on manufacturer. Quickfuel makes good carbs at a decent price, Profroms aren't quite as high end as a Quickfuel, but work well. Demons are decent but you have to clean the machining crap out of them before you bolt them up. A Quickfuel Q series 750 with downleg boosters and adjustable metering blocks would be my choice, whether or not you get one with a choke is up to you. Mechanical secondary unless it's a heavy car with tall gearing.
There's a formula to see your cfm requirement for a carb.
c.i. x peak h.p. rpm=
whatever that equals divided by 3456= needed cfm's
not sure what that cam pulls to rpm wise in a 347 with those heads, but here's an example basing it on 6500rpms.
347 x 6,500= 2,255,500
2,255,500 / 3,456 = 652.63 cfm
Would be best with a 650cfm carb
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
