Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
Speed density gt40p
Old Dec 16, 2008 | 09:48 PM
88lx50ab's Avatar
88lx50ab
Default Speed density gt40p
hey i have a speed density setup and i was wondering if anyone had any problems with a gt40 p intake 70mm throttle body and a cold air intake. any tips or suggestions would be appreciated. THanks
Old Dec 16, 2008 | 10:36 PM
Hamutoff's Avatar
Hamutoff
I know folks run the p heads and differeing air paths from stock but they have an aftermarket computer and/or a tune of some sort, you could just 'go for it' and see if you run smooth then take steps until you are satisfied with the operation...
have you given thought to the mass airflow conversion? Here are some quick links
http://fordfuelinjection.com/?p=5
http://www.fordmuscle.com/archives/2...sion/index.php
http://www.corral.net/tech/powerplant/maf_tech_2.html
http://www.fordracingparts.com
M-9000-A51* 1986-88(1) Mustang 5.0L HO EFI only Manual
M-9000-B50* 1986-88(1) Mustang 5.0L HO EFI only Automatic
Old Dec 16, 2008 | 10:45 PM
Night Terror's Avatar
Night Terror
shouldn't have any problems at all... i would jsut crank up the FP a little bit...
a few people on her ran more "extreme" set ups with stock SD system and 19lbers
my combo in my sig will be done with stock SD computer and 21lb injectors
Old Dec 18, 2008 | 09:59 PM
88lx50ab's Avatar
88lx50ab
how do you adjust that fuel pressure
Old Dec 18, 2008 | 10:15 PM
ZachW04Stang's Avatar
ZachW04Stang
You shouldn't have to adjust fuel pressure. The stock 38psi at wot should be fine. My car with speed density I had a comp cam, gt40p heads, and tf intake and the car's a/f stayed between 12.4-14.4 on the dyno with absolutly no tuning except setting the timing.
Old Dec 19, 2008 | 12:20 AM
minnow81469's Avatar
minnow81469
I thought if you switched to the gt40 p you had to have the car tuned cause it wouldnt run right
Old Dec 19, 2008 | 06:40 AM
Joel5.0's Avatar
Joel5.0
The computer will never know what heads you have installed, you could install Cleveland heads on the Windsor SBF and as long as there's a good vacuum signal from a manifold port, the EEC will do it's job. IOW... GT40p heads installed correctly = no problems in a speed density setup.
Old Dec 30, 2008 | 08:38 PM
86GT 93LX's Avatar
86GT 93LX
I don't think you will have issues except on the larger airflow due to the 70mm t.b.
I say just do it and if you have problems switch to mass air and you'll be fine. Sd reads vac mass reads air so if you don't mess with vac pressure it should be good
Old Dec 31, 2008 | 06:52 AM
Joel5.0's Avatar
Joel5.0
The TB ID will not cause any problems, I installed an 80mm TB on a '86 SD setup with an AOD, and it worked better than I expected.
Old Jan 27, 2009 | 09:59 PM
stangbanger87's Avatar
stangbanger87
i had gt40p heads and intake on my 87 with a 70mm tb and had no trouble out of mine at all .
you should have no trouble out of this set up what so ever with sd .
