Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
Cam Specs
Old Jan 7, 2009 | 09:48 PM
LookinFORfast's Avatar
LookinFORfast
Default Cam Specs
I was wondering what cam i should use for a mild 302. As of right now i have an Edelbrock Performer intake,gt40 heads, and a 750 Holley (too much carb?). I wanted to use one of Ford's b,e,f, or x cams i just don't know which. I'd like street-able power nothing to wild. Thanks for the help.
Old Jan 8, 2009 | 12:41 PM
Portmaster's Avatar
Portmaster
It's way to much carb. A 600-660 would give you better off throttle power. As far a which cam I would use a Comp Cams XE264HR. It will make power all the way from right off throttle until the heads run out of breath
Old Jan 22, 2009 | 12:08 AM
hypersurf1's Avatar
hypersurf1
Would this cam be good for a 88 GT SD with AFR165 heads and 1.7 RR?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
