Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
MSD 6A + Carb Question
Old Feb 1, 2009 | 06:15 PM
xmysignature's Avatar
xmysignature
Default MSD 6A + Carb Question
As far as all the splicing goes, we use the two 8 pin connectors near the brake booster to splice into the ignition box right? Im using a msd 6a which has an orange "to positive coil" and a black "to negative coil" wire, the person i bought the car from had both the black and orange to the negative and the full red wire to the positive side. It ran but the tach didnt work, and when i rewired it where the orange went to the positive side and the black to the negative with the full read to the tach theres no spark. i need help..
Old Feb 1, 2009 | 06:17 PM
xmysignature
BTW I only have the green rectangular 8 pin connector near where the eec goes does this effect the carb swap. None of my lights work, is this because theres no ecu in the car?
Old Feb 2, 2009 | 06:36 AM
Portmaster's Avatar
Portmaster
Black to coil neg
orange to coil positive
Red to original incoming coil positive wire
White to original incoming coil neg
Heavy Red wire to battery Pos
Heavy Black wire to Batter Neg
Mag pickup wires need to be taped off and not used.
wwmost
May 25, 2005 11:15 PM
5.0_stang
Jan 13, 2005 09:49 PM
5.0_stang
Jan 13, 2005 12:40 PM
Grimace5.0
Sep 22, 2004 12:57 AM
