which is better EFI or CARB?
i have a 95 gt with a 331 stroker in it with edlebrock aluminum heads, trickflow stage one cam, lifters, roller rockers, high flow oil pump, ac delete, smog delete, 3.73 gears, off-road x pipe, shorty headers, and a few other things that i cant think of right now but im thinking about going carbed. What does everyone think about that?
If you already have EFI then keep it. Converting to a good carb and getting all the tuning parts etc will cost more than you think. And just being honest, but if you have to ask if you'll gain anything by going to carb, then it's unlikely you could properly tune one. There's a lot more to it than just changing jets if you want to get a good carb really dialed in.
If you have nothing for induction and either learn how to tune a carb(Pro Systems sells videos on that) or know someone who does, then building a from scratch system, carb is cheaper.
As far as power, it really ends up being the same either way. Neither system has enough advantage over the other when properly set up to justify swapping just for a power gain.
thanks for all the input...i dont know how to tune a carb but i have a few good friends that do and are willing to help me...swapping over to carb was recommended from a car builder said it would be a more lean power or something like that
Pfffft. Sounds like it was someone who's a carburetor nut swinger and thinks everything should be carb. You already have decent EFI, I'd stay with it. Chances are swapping to a carb will result in more performance problems than improvements, and it can take a while to work bugs out of a carbureted setup.
yeah that is possible but as far as i know the two guys that i have telling me i should switch over never made it sound like that but it is possible but i already sold the setup i had so i could go get the car...i had it in ohio before i joinded the navy so i had to go get it. i just think it is easier to go carbed than to stay injected because it cost a lot more to upgrade the fuel system then the carb set up
So you have no induction system right now? If so, yeah, carb is cheaper and easier, but you have to know what you're doing to get them tuned. I did a header swap the other week and it threw my tune out, and if you'd seen me messing with it today trying to get it right you'd think twice about using a carb.
I may even have to change the emulsion in the metering block to get it right.
