StangSuspension.com Your source for late model Ford Mustang suspension parts and performance!
2006 Getting started questions
Old Mar 5, 2006 | 11:44 AM
jbailer's Avatar
jbailer
Default 2006 Getting started questions
I just bought a 2006 GT that I intend to use for show/drag primarily. The car will see a little street time but not much and always in perfect weather. I see I'm somewhat limited in suspension upgrades by availability since the application is so new but was wondering if I could get a recommendation on a setup for my application.
I purchased and am in the middle of applying the Cervini's body kit. I am somewhat limiting my performance capabilities with the 20x10" wheels (rear). I have a set of BF Goodrich g-Force T/A KDW2 285/30YR20 XL tires on order for the rear with 20x8.5" wheels and 255/35WR20 XL tires for the front. I know it's best to stick to one application (drag/road/show) but I really want a combination with preference towards drag but still streetable with a lowered stance.
Cervini's was using parts from Kenny Brown but I understand parts availability may be an issue now. Can you recommend a complete setup with those goals in mind? I know a little about suspension setups but only enough to know I need serious help from professionals. Thanks! -Joe
*edit: Oooops, forgot to mention power goals should be in the 400+ RWHP range and it's an auto (please don't laugh [sm=smiley5.gif]
Old Mar 7, 2006 | 04:47 PM
STANGSUSPENSION's Avatar
STANGSUSPENSION
Former Sponsor
Default RE: 2006 Getting started questions
The two most common modifications for the 05-06 are springs and shocks.
I would suggest either the Steeda or Eibach springs. Both only lower about 1 inch, so you will not run into rubbing/scraping problems with your Cervini body kit.
For Shocks/Struts I'd recommend the Tokico D-spec kit. These are fully adjustable and will allow you to soften up the rear end at the drag strip, then tighten it up back on the street.
I believe the above two mods will be a perfect combo of drag/street/appearance...
Of course, there are tons of other modifications you can do, such as strut braces, chassis stiffening, bumpsteer kit, etc. but I'd start with the above...
Sincerely,
Old Mar 8, 2006 | 07:07 PM
jbailer's Avatar
jbailer
Thanks for the info! If it were yours and you wanted to do it all at once, what else would you add to it? -Joe
Old Mar 10, 2006 | 02:12 AM
STANGSUSPENSION
Former Sponsor
If you wanted to go above and beyond shocks/struts and springs...... sky is the limit!
There are many other modifications you can do... I would start with Swaybars, Rear Control arms (lower and upper 3rd link), as well as a new adjustable panhard bar.
For the front end, the control arm bushings, strut bars, and brake upgrades are very popular...
Luclin999
Sep 7, 2015 11:33 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
Calizic
Aug 28, 2015 01:46 PM
stormesixx
Aug 25, 2015 09:11 AM
Mignav001
Aug 11, 2015 02:28 PM
